alternator
Old Oct 14, 2023 | 03:39 PM
Cm3geese's Avatar
Default alternator
I have a Land Rover LR2 2008 6 cylinder. I have an issue I am trying to resolve with the alternator or Alternator gearbox. This is the first I have ever heard of an alternator gearbox.
I was having it sounding like a diesel rattling. It then had a squealing noise like a bearing when I shut it off. I took it to the repair shop, and they say it is the alternator gearbox that the sound was from. Is there even such a thing?
Old Oct 15, 2023 | 12:59 PM
merlinj79's Avatar
Assuming 3.2 i6 engine...
The Alt has a funky mechanical drive direct from the engine, instead of the usual belt drive.
The alternator itself should not have a gearbox as far as I know, maybe the mechanic thinks there's an issue with the mechanical drive from the engine block, there are gears in that. That sounds expensive...
Old Oct 15, 2023 | 01:18 PM
Cm3geese's Avatar
Yes it is the 3.2 i6
Old Oct 16, 2023 | 04:51 PM
flybd5's Avatar
Removing and replacing the alternator is a heavy job, you have to remove the intake manifold and move things aside to get to it. Volvo in their bizarre minds decided that using a normal belt-driven alternator was a bad idea, so they have it buried in the engine compartment. It is driven by gears in the engine.
Itrujillo
LR2
Jun 15, 2018 07:12 AM
JumPeR04
Dec 17, 2009 07:57 PM
lennie5936
Jan 2, 2009 09:42 AM
cplthomas
Dec 8, 2008 02:24 PM
ibncalb
Jun 2, 2005 09:02 AM
