Alternator works intermittently, sometimes not at all
Old Sep 28, 2023 | 04:46 AM
NotOverRover's Avatar
Default Alternator works intermittently, sometimes not at all
Alternator works intermittently, what's up with the blue wire? Just when I think I need to order an alternator it starts working. I disconnected the little blue wire started the engine and after a minute the battery light came on and of course it was not charging the battery. But when I had to move it I plugged the blue wire back in and the light never came back on and it was kicking out 14v. So I took it down the road for quite a few miles before I came back and it still never came on. With all the different variables for the alternator / generator to work I can't get an accurate reading for because of this or because of that. what is a definitive test?
Old Sep 28, 2023 | 08:52 AM
OldKarz's Avatar
I would say your alternator is OK. The blue wire is for the field and is controlled by the ECU. It sounds like you need to do a really good cleaning of the connector. Use a grease and corrosion cleaner. They do the job differently and one will not fix the other problem.
Old Sep 28, 2023 | 09:44 AM
merlinj79's Avatar
Can't hurt to check and clean all of the alternator connectors, including big wires. And engine grounds.
But unless you're in a high corrosion area, modern connectors usually don't get gunked up.
It's still possible that the alternator is just failing, that's common enough.
GivenyDiscoII
Dec 27, 2022 07:47 AM
PeterBada
Nov 11, 2021 03:22 PM
Lando123
Sep 25, 2021 05:26 AM
Daedrix
Jul 13, 2016 08:47 PM
trospierski
Jun 19, 2012 06:53 PM
