Bluetooth for 2011 LR2
Old May 7, 2021 | 08:55 PM
flyer08's Avatar
Default Bluetooth for 2011 LR2
I know there has been a lot of Bluetooth info here but would like the latest.
Have 2011 LR2 with no Bluetooth.... What's a solution without breaking the bank, very few wires, and effective. Would prefer solution that pairs with both ios and android. And works well for phone, streaming music, and car stereo
Old May 8, 2021 | 08:45 AM
merlinj79's Avatar
I had something like that years ago in an acura TSX, which like the LR2 has a very integrated (pre-BT) OEM stereo.
Might be hard to find these days, probably want to ask a shop that installs that kind of thing. When I had that installed in the TSX, I did ask about the LR2, he said it could be done but would be complicated. The only way the BT can "take over" the OEM sound system for incoming calls would be to splice into the speaker amp wires so the BT can disconnect the stereo input when it needs to.
For BT music it could probably be wired to the stereo aux input. I guess you could manually select stereo aux when you hear an incoming call on your phone, or just leave it aux all the time if you don't use FM or CD for music.
You see the problem. I don't think there's a cheap solution, since there's going to be wiring involved. But ask a shop.
Old May 8, 2021 | 10:06 AM
flybd5's Avatar
Does your entertainment system include any cellular functionality? If not, then you'll need to install a completely new system, a bluetooth module, a bluetooth antenna and the microphone module. You're better off just upgrading to one of the third party Android entertainment heads that includes all of that with Android.
If your system does include cellular functionality then either the bluetooth is broken, someone took it out, or you haven't been using it correctly.
There is no solution with very few wires. The simplest solution is a third party bluetooth speaker/mike that clips onto the visor, or get a Garmin GPS with the functionality.
Old May 8, 2021 | 03:59 PM
BlairMaynard's Avatar
Old May 8, 2021 | 04:03 PM
flybd5's Avatar
There are a number of third party systems like that. I would suggest you shop very carefully and look for clear evidence that the system can interface with the car and the steering wheels controls. I know it can be done but I can't remember where I saw that.
Old May 11, 2021 | 12:08 AM
flyer08's Avatar
Thanks for the replies and info
Got a on the cheap solution that may work.... or not. Saw another member post same problem and after much work, came to a simple solution.
A Bluetooth USB with built in short AUX cord. Will try on totally non-Bluetooth 2011 LR2 and 2006, just updated phone only Bluetooth 2011 LR3
Its a Bluetooth USB with short AUX cord... link below
Amazon Amazon
Will let you know results, good and bad.
Quick off topic for Flyb5.... Love aviation. Most fun was owning and flying two seater SeaRey low and slow with over shorelines
https://www.searey.com/
Fyi.... Dakota Travler says GAP tool may update LR3 Bluetooth so will not need to bind phone and LR3 each time I get in. GAP seem to have done job after some re-flashing
So thanks DT
Old May 11, 2021 | 08:59 AM
merlinj79's Avatar
https://www.amazon.com/Firefly-Bluet.../dp/B01HDO66NK
Should work fine. The only stereo controls which will work will be volume though.. that aux input feed is audio only, no digital stuff so you can't pause, skip songs, answer the phone, initiate a phone call, etc. Actually you probably won't be able to use the phone for calls because there's no microphone in the car, unless maybe the phone is smart enough to know to use it's own mic.
You should be able to use a cigarette lighter 12V to USB power supply, there's a 12V socket right next to the aux input on the rear console . Be careful though, the rear console 12V socket stays powered at all times. That creates two potential problems:
1. Constant battery drain. I leave a USB power supply in that socket all the time, but as long as nothing is plugged in to charge the current draw is negligible for the big LR2 battery, basically just an LED. But the bluetooth dongle will draw a little more power. My guess is it will be fine overnight or for a day or two but I wouldn't go on vacation for a week+ and leave it plugged in.
2. If it stays powered, the dongle will try to stay connected to your phone... if your garage/parking spot is near your house, it might be able to do that so phone calls would be directed to the car, not the phone's speaker. Might need to unplug the dongle when you get out of the car to avoid that.
This is similar to how I use my phone for music in the LR2... except I just use an audio cable and plug it in to the console aux input. I may actually but one of these gadgets though, just so I don't have to plug the phone in every time.
Another aviation fan here, also envious of flybd5... my airbus is about as far from that as it gets.
Old May 11, 2021 | 09:43 AM
flybd5's Avatar
I've been out of the BD-5 world for a while now but still maintain the info web site at bd5.com for those who are interested. And I still have the Guinness record for the World's Smallest Jet. I switched to LSA for about a week after I finished restoring an N-3 Pup that was languishing in a barn, but then sold that to finish the restoration of a classic 1965 Italian Aer-Pegaso M100S glider. I took that with me to Germany in 2015 and flew it exclusive in winch launches (Top Gun has NOTHING on that!) for 4.5 years, then brought it back to the US. It's now for sale or trade: https://boston.craigslist.org/bmw/av...302669631.html I want to get myself an RV or skoolie to putt-putt around the country with the wife and dog. I like the Searey, I met a builder in Puerto Rico who was working on it in his enclosed garage at an apartment building in San Juan. I wouldn't mind owning one if it were ELSA-qualified. But right now I have other priorities.
GATORPLANT
LR2
Mar 29, 2010 07:17 PM
maru4
LR2
May 27, 2009 12:55 PM
tyty
LR2
Mar 8, 2009 03:51 PM
okarpf
LR2
Feb 19, 2008 12:48 PM
vernmangk
LR2
Feb 5, 2008 10:12 AM
