Bolts to put engine on stand
Old Jan 14, 2026 | 08:09 PM
flybd5's Avatar
Default Bolts to put engine on stand
Does anyone know what size bolts I need to mount the engine block on a stand? Are they M14x1.5? I'm picking up my old engine from the mechanic on the 23rd and I want to transfer it to the engine stand after removing the flywheel, cover, etc.
Old Jan 15, 2026 | 10:56 AM
LR2driver's Avatar
To be sure, you may need to visit your local Volvo parts dealer and ask them to lookup the bolt size for the B6324S engine. Does the stand attach using the same bolt holes as the transmission?
Old Jan 15, 2026 | 11:01 AM
flybd5's Avatar
Harbor Freight Tools engine stands have universal adapter mounting plates. I will check with the volvo dealer. thanks!
Old Jan 15, 2026 | 11:29 AM
flybd5's Avatar
The local dealer had no clue, so I checked with a bolt vendor and I found out that sells a set. It comes with the four correct M12x1.75x105mm bolts and an additional set of four M10x1.75x100mm for smaller engines.
bmeier
Apr 16, 2021 06:18 PM
merebel
Mar 20, 2021 02:20 PM
Fastercat
Jul 18, 2020 04:39 PM
Bryan H
Jul 25, 2010 07:15 AM
rambo
Jan 6, 2009 08:33 PM
