Engine Fault Code P2407 Evap Leak Detection Pump Sense Circuit
Old Apr 11, 2019 | 10:49 AM
parthea's Avatar
Default Engine Fault Code P2407 Evap Leak Detection Pump Sense Circuit
I had code P2407 Evap Leak Detection Pump Sense Circuit on my 2014 Land Rover LR2 recently. I read that this can happen if the gas cap is not fully seated. I've reseated the fuel cap and cleared the code. I'm hoping it doesn't reappear. Has anyone else seen this one before?
Old Apr 21, 2019 | 11:08 AM
Pavilion's Avatar
Hi, Sorry I am not familiar with your landrover but I do know a few things about evap systems. Yes a bad gasket on the cap can cause a leak. You will have to wait for the readiness system to run a test on the circuit before you will see if it is cured. The wording used on different scanners can be misleading especially some of the Matco ones where they have been translated from English by Chinese. Depending on the placement of your components, it is possible that the tank vent has become packed up with dirt and is sticking. they are sometimes up in the wheelwell by the filler neck and most often on top of the tank so they do get a fair bit of crap in them.. May I ask how you got the code and what scanner you used?
Old Apr 21, 2019 | 12:00 PM
parthea's Avatar
Default Problem solved
Thanks for the quick reply. I reseated the gas cap and cleared the code. The engine light has been off now for 1000 km. If the issue reappears ill definitely look into those other possible solutions. I used OBDLINK MX by Scantool.net .
Old Apr 21, 2019 | 03:44 PM
Pavilion's Avatar
Ty for the info. Glad it was simple. You have definitely covered enough distance for it to run the test so fingers crossed its sorted..
emncfi
Mar 6, 2018 03:35 PM
pwaltrip
Jul 26, 2016 10:00 PM
robgusto
Sep 2, 2012 03:33 PM
wild driver
Jun 7, 2012 09:25 AM
tlester72
Jan 21, 2008 08:17 PM
