Flex Brake Hoses
Old 12-27-2021, 10:23 AM
ThorInc's Avatar
Check out this ebay listing and the specific notes re VIN, etc.:
https://www.ebay.ca/itm/202563678530
This is the set I purchased and currently use.
Manu part#LRV-4-010-FK
Old 12-27-2021, 11:42 AM
LR2driver's Avatar
Originally Posted by merlinj79
Be careful!
For the 2008 model there are two versions of the rear caliper, the older one may use a tapered thread for the hose, the newer is a straight thread (with an oring?). I think it changed mid- MY and I assume a later MY's use the straight thread.
Atlantic British sent me the wrong ones, and they never could figure it out... shortly after my issue, they just stopped selling the rear hoses. If you can't get clarity on which hose you need, just get the rears from the dealer, referencing your VIN....
I check the Atlantic British website as a useful reference even if I don't buy from them. I was wondering why they didn't offer the rear hoses! Ah, you have the backstory on that.
Old 12-27-2021, 11:55 AM
LR2driver's Avatar
In case the hoses don't come with hardware, what is the size for the Banjo Bolt and crush washers? Same size for both front and rear?
Old 12-27-2021, 12:11 PM
flybd5's Avatar
I can't find any ref for a part number for banjo bolts or crush washers. Like I said, only buy the hoses from someone who includes those parts if needed.
Old 07-16-2023, 04:38 PM
merlinj79's Avatar
DANGER!
Replaced the flex hoses a little over four years ago and the right front failed today, where the rubber enters the fitting. Didn't pop off but good enough leak that there was no fluid and no braking by the time my wife drove it home.
I bought the parts at Atlantic British.
Old 07-16-2023, 07:43 PM
LR2driver's Avatar
DANGER!
Do your hoses have a brand name on them? The ones I got are made by Sunsong. I haven't gotten around to putting them on yet.
Old 07-17-2023, 12:50 PM
merlinj79's Avatar
I got them from Atlantic British, but don't recall the packaging. I'll look at the hoses when I pull them off (they are ALL coming off ).
Wife admitted to a panic stop, but still they should be up for that. Especially four years old. Jesus.
I'm done with AB for sure... rear hoses I suspect are the wrong part, and fronts that fail???
Old 07-17-2023, 04:22 PM
ThorInc's Avatar
No panic stop should cause that crap, that's why we all have brakes....I would bitch to AB to high heaven since if you had not noticed the fluid on the ground, the situation could be dire. 4 years should not be the life unless you were submerged in the ocean regularly.
Old 07-17-2023, 05:32 PM
LR2driver's Avatar
DANGER!
Did it fail at the fitting on the caliper side of the hose, or the hard brake line side?
Old 07-17-2023, 05:55 PM
merlinj79's Avatar
Caliper side.
Quick Reply: Flex Brake Hoses
