Haldex filter kit??
Old Nov 2, 2024 | 05:14 PM
Viking1's Avatar
Default Haldex filter kit??
Hi Guys,
Can anyone direct me on the correct Haldex filter kit for a 2008 LR two getting ready to service it
Old Nov 2, 2024 | 06:18 PM
LR2driver's Avatar
I think @p_gill has done this and would know.
Old Nov 2, 2024 | 08:05 PM
ThorInc's Avatar
Most likely a gen 3 haldex. Google gen 3 haldex kit....Volvo sells the fluid much cheaper than LR.
Old Nov 3, 2024 | 11:49 AM
merlinj79's Avatar
https://www.fcpeuro.com/products/vol...oaAtUZEALw_wcB
Old Nov 4, 2024 | 03:07 AM
Viking1's Avatar
Default Haldex filter 2008 LR2
It’s early Monday morning. Thanks for the replies guys.
I believe it’s a Gen3 filter the smaller filter with the small spring.The people at FCP responded.I just found it in my junk mail.They need the vin number to verify the correct filter.
Ill send it to them today. TBC
[img alt="I believe I’m going to find out that this is the correct Haldex filter for a 2008 LR2 and identified as a Gen 3 Haldex unit filter Amozon offers an aftermarket unit.
It’s shorter and incorporates a small spring .I believe you are correct
"]https://cimg7.ibsrv.net/gimg/landroverforums.com-vbulletin/1284x1114/img_6317_1b181fa6089e307321a7c879b3ae5d2f5ec3b481. jpeg[/img]
I believe I’m going to find out that this is the correct Haldex filter for a 2008 LR2 and identified as a Gen 3 Haldex unit filter Amozon offers an aftermarket unit. It’s shorter and incorporates a small spring .I believe you are correct Gen 3
Old Nov 8, 2024 | 06:38 AM
Viking1's Avatar
Default 2008 LR2 Haldex filter cont.
Ok so it turns out that the correct filter for the Haldex unit in a 2008 LR two is a GEN three a GEN three haldex filter is a smaller filter with a spring on the end of it again again Gen three Haldex filter for a 2008 LR two is the smaller filter with the spring on the outside end with a new cover and bolts service complete thank you again
Old Nov 8, 2024 | 10:47 AM
merlinj79's Avatar
Yes 2008 is always Gen 3. I think a later model year might have switched to Gen 4 mid-year.
Old Nov 8, 2024 | 12:38 PM
Viking1's Avatar
Default Aftermarket filter
OIL FILTER KIT AOC COUPLING OIL...
Amazon Amazon
normally, I wouldn’t use an aftermarket filter, but they look exactly the same so I went with it. It’s a lot cheaper available at Amazon.
Old Nov 8, 2024 | 06:50 PM
flybd5's Avatar
Originally Posted by Viking1
OIL FILTER KIT AOC COUPLING OIL... https://www.amazon.com/dp/B08J6SKNPX...p_mob_ap_share
Looking the same and being the same are two different things. Do you really think it's worth taking a chance on something so important? I sure as heck would not make that bet.
Old Nov 8, 2024 | 08:59 PM
Viking1's Avatar
I’m sure you’re correct. The differential. was replaced at 40,000 miles like most of the LR two differentials I replaced the filter three years ago had approximately 80,000 miles with an aftermarket filter when I pulled it out yesterday it looked pretty decent and the rear has been OK and the Haldex unit it’s been OK no faults just keeping up on the service, I had a GEN 4 Borg Warner filter purchased it by mistake compared to the GEN three aftermarket and the GEN four identical maybe the guts were different. Maybe the check was slightly different but judging from the one I just pulled out which was close to four years old and then aftermarket I took a chance time will tell . Appreciate your professional input as always. Have a great night.
