Has anyone replaced the fuel pump?
I did a cursory search on this and it appears that you have to drop the exhaust, driveshaft, and gas tank to replace the fuel pump/ fuel filter. Isn't it easier to just cut the floor hole bigger to replace it out of the top of the tank like people do with the P38 Rover? Ford Focus's are like that too. It's much easier just to cut the hole bigger under the seat to replace the pump than to drop everything underneath..
Hi all, To bring up an older thread: my LR2 finally puked in my driveway today. I'm pretty sure the fuel pump is done because it's turning over and not starting. So has anyone cut the interior floor hole bigger to replace the fuel pump out of the top of the gas tank? I don't have the facilities or the money to have it replaced from under the car. I could either replace it myself from the top for $150, or would have to pay a shop to replace it from the bottom for $1500. What does anyone think?
The existing access hole in the floor looks like only for the electrical plug and gas/vent line connections. There's no way to replace the pump from the top unless I cut the floor hole about two times bigger, to be able to cut out the styrofoam and then hammer the retaining ring off. Then the pump should come out nicely. I don't know why they didn't make the hole bigger at the factory, it seems to be 90% easier to replace it from above instead of dropping the exhaust, drive shaft, e brake cables and gas tank..
Well it's not getting gas. It just turns over and will run for a second then stall out. I took the fuel pump access plate off in the floor and can see it's the original pump and has never been replaced. The car is 15 years old and has 120k miles on it, so I'm wagering the fuel pump is the problem.
Do a proper troubleshooting, save yourself a needless wild goose chase and unnecessary work and costs. If the code reader reports codes, post them here. If you don't have a good code reader take it to your local auto parts store. They generally scan the vehicle for free.
guy (10-30-2023)
