Land Rover LR2 Volumetric Efficiency (VE)
Jade Dockery (09-23-2019)
https://torque-bhp.com/wiki/Volumetric_Efficiency
I assume that you are looking at something like the VE from the Torque App
The calculation is based on how much air enters the engine vs. the theoretical 3.2 liters
To get higher VE you want to be at the Torque peak, which is about 3500 RPMs for a LR2
So if you want to see a higher number then put the transmission in manual mode and drive around and try to keep the revs at 3500 or a bit more
ideally find a long steep hill and foot to the floor at 3500 RPM
Then check the VE
Note: higher VE will make the engine seem very responsive but it will be horrible for fuel economy
Because the LR2 has variable valve lift (Intake) and variable valve timing (intakeand exhaust) the ECU is reducing the VE to get better fuel economy (Edit: Variable timing and lift is on the intake only)
More info
https://www.matthewsvolvosite.com/fo...p?f=31&t=90067
Have fun
Paul
Then check the VE
More info
Have fun
Paul
Last edited by p_gill; 09-17-2019 at 12:36 PM. Reason: corrected technical description
ThorInc (09-17-2019)
