Land Rover LR2 Volumetric Efficiency (VE)
Old May 25, 2019 | 03:48 PM
LR2driver's Avatar
Default Land Rover LR2 Volumetric Efficiency (VE)
Using an OBD2 reader/logger, it calculated my 2008 LR2's Volumetric Efficiency at 60%. I understand that you like to see values of at least 75 or 80%, so my VE of 60 is low.
Does anyone else have a VE measurement of their LR2 to share?
Old Sep 15, 2019 | 12:29 PM
disconic's Avatar
I'm trying to find out what mine is so I can enhance fuel mileage calculations on torque pro. LR2? Never heard of it. Are you referring to the discovery 2?
Old Sep 15, 2019 | 01:38 PM
ThorInc's Avatar
The LR2 is the North American equivalent of the Freelander 2.
Old Sep 16, 2019 | 10:19 PM
p_gill's Avatar
https://torque-bhp.com/wiki/Volumetric_Efficiency
I assume that you are looking at something like the VE from the Torque App
The calculation is based on how much air enters the engine vs. the theoretical 3.2 liters
To get higher VE you want to be at the Torque peak, which is about 3500 RPMs for a LR2
So if you want to see a higher number then put the transmission in manual mode and drive around and try to keep the revs at 3500 or a bit more
ideally find a long steep hill and foot to the floor at 3500 RPM
Then check the VE
Note: higher VE will make the engine seem very responsive but it will be horrible for fuel economy
Because the LR2 has variable valve lift (Intake) and variable valve timing (intake and exhaust) the ECU is reducing the VE to get better fuel economy (Edit: Variable timing and lift is on the intake only)
More info
https://www.matthewsvolvosite.com/fo...p?f=31&t=90067
Have fun
Paul
Last edited by p_gill; Sep 17, 2019 at 12:36 PM. Reason: corrected technical description
kind16
LR2
Sep 15, 2019 01:00 PM
Newlr2guy
LR2
Jun 29, 2019 08:29 AM
roverreitzel7
LR2
Feb 27, 2013 09:51 AM
ronx
Other
May 15, 2007 11:08 AM
05LandRover
Freelander
Dec 18, 2006 04:17 AM
