Looking at a 70,000 Mile LR2 - What should I look for
Old May 31, 2025 | 01:41 PM
robthomas1660's Avatar
Default Looking at a 70,000 Mile LR2 - What should I look for
Alright everyone, looking at getting an 2008 LR2 with 70,000 miles. Petrol engine. Big fan of these vehicles and found one in my price range.
Any tips that I should look out for?
Or things I should try to do on the test drive?
Anyone against these vehicles? Or anything in particular that I should run from if I catch it?
Old May 31, 2025 | 03:34 PM
LR2driver's Avatar
That's a low mileage barn find! I would be suspicious that the odometer was set back.
Old May 31, 2025 | 11:32 PM
flybd5's Avatar
These days it is almost impossible to get away with this because of services like CarFax that track the vehicle's history.
I assume the person who posted this ran a CarFax check...
Old Jun 1, 2025 | 11:27 AM
merlinj79's Avatar
It's also harder to set back a digital odometer.
I would probably buy one at 70K if it was in good cosmetic shape (ie garaged).
Make sure suspension feels tight and it shifts OK (assuming automatic). But jerky shifting at 70K is more likely just motor mounts, or needs new ATF at that mileage, so that wouldn't be a show stopper for me.
Verify that tire wear is even, another indicator of suspension issues.
Verify that the rear drive coupler (Haldex) engages... from a stop on pavement, hit the gas aggressively, it should accelerate without the front tires squealing.
Use a scantool to check for codes. I wouldn't worry about any codes related to CAN network, entertainment system, etc.
Engine should be fine at that mileage, but if you have any doubt about actual mileage, get a compression check done.
If you buy it, come back here for a discussion about maintenance schedule... the OEM schedule is NOT adequate for many items, and at 70K you'll want to do some specific fluid changes asap.
Old Jun 17, 2025 | 07:52 AM
Thank you everyone! Did do a Carfax and verified mileage. Work was done on it, not far from me, so that's a plus.
Old Jun 17, 2025 | 09:49 AM
geotrash's Avatar
One of the weak spots on these is rear differential pinion bearings. The differential should be silent while driving. If there is a drone or a roaring from the rear end while driving, I would either not buy it or buy it and budget $2K for a rebuild.
Old Jun 17, 2025 | 10:19 AM
flybd5's Avatar
Have a chat with that mechanic about the car before buying it, ensure he/she still wants to work on it when necessary.
Old Jul 4, 2025 | 09:32 AM
irontmp's Avatar
Banned
Any tips that I should look out for, except vehicle history services?
Check for full service history, smooth transmission shifts, and listen for rear diff or haldex unit noise. Look for coolant leaks around the thermostat and water pump. Test all electronics, especially windows and sunroof. On the test drive, take it to highway speeds, do tight turns to check AWD function, and brake firmly to feel for vibration. Suspension clunks can mean worn components. If everything checks out and maintenance is solid, the 2008 LR2 can be a good buy.
Colorado Car
LR2
21
Nov 5, 2021 12:59 PM
Newlr2guy
LR2
Jun 29, 2019 08:29 AM
Kflex
Jan 19, 2016 08:14 PM
sunofman
LR2
Oct 2, 2015 03:28 PM
05LandRover
Freelander
Dec 18, 2006 04:17 AM
