Lower engine shield
Old Feb 7, 2024 | 01:12 PM
  #31
flybd5's Avatar
Originally Posted by flybd5
Ok, I got some better info from the local dealer. The LR032033 is indeed cheaper and it is for the DIESEL model. The LR006779 is for the gas model. The parts guy suspects the 032033 will fit the gas model trucks but has a cutout for the oil filter that the gas model doesn't have because the oil filter is accessed from the top of the engine.
So, can you folks who have diesels maybe confirm the bottom skid plates are otherwise the same?
Once again the EU used parts market saves the day. Found a used but very clean LR006779 in Belgium for €140.75 including shipping to the US. I will update the thread when I get it.
Old Feb 7, 2024 | 05:50 PM
  #32
LR2driver's Avatar
Talking
Cool. Maybe they'll throw in a can of Duvel
Old Feb 7, 2024 | 06:00 PM
  #33
flybd5's Avatar
Can? Sacrilege!
Old Feb 7, 2024 | 06:02 PM
  #34
flybd5's Avatar
Originally Posted by SteveinRI
Good find. I got mine at Tiverton Auto Parts along with he driveshaft. The bolts are 3/8-16.
What is the length of the bolts, and do they have flanged heads? The LR catalog says they are M10x25mm and the nuts are retained by M10 "U" retainer nuts.
Old Feb 8, 2024 | 11:10 AM
  #35
merlinj79's Avatar
Flanged, shaft is 25mm. Also has a built-in lock washer.
Pretty sure you could get away with longer, or just a generic bolt with a washer.
Old Feb 8, 2024 | 11:14 AM
  #36
flybd5's Avatar
Ok, those are easy to find if it doesn't come with them. Thanks!
Old Feb 8, 2024 | 12:26 PM
  #37
merlinj79's Avatar
The washer has lock serrations which match serrations on the bolt flange.
Old Feb 9, 2024 | 03:50 PM
  #38
LR2driver's Avatar
See post #10 above. They get pricey if you are buying all 6 of them.
Old Feb 9, 2024 | 08:03 PM
  #39
flybd5's Avatar
How many of these does the LR2 skid plate need? I thought it was four. Now I am wondering if the skid plate I bought comes with the bolts.
Old Feb 10, 2024 | 09:54 AM
  #40
merlinj79's Avatar
It's six, two in the back, two in the front, and one on each side.
Also the retainer nuts might still be on your car, the clips are pretty tight. Guess they might be rusty though in your neck of the woods.
