LR2 - 2.0 turbo (Ford Ecotec) - achievable life mileage
Hi Guy(s) - I did a bit of research - engine timing chain premature failures (Ford eco boost) have been associated with lack of regular oil change regime (dirty oil). Premature rear diff failures likewise - we know the specific bearing that fails in the rear diff and clean oil will definitely promote longevity. (Incidentally I have an aged Porsche Boxster, this car is synonymous with a IMS bearing failure, in general the failure elimination/remediation is based on lubricating the IMS bearing with fresh oil - the original bearing installed has a debris barrier (that actually prevents oil flow thru/around the bearing) as bearing was 'sealed for life' - sometimes 'life' was about 30k miles ) When the bearing fails it usually takes the engine with it due to the shrapnel that is liberated from the failed bearing - shocking design/manufacture failure.
Overall changing all the fluids makes sense but the evidence is a bit less than 100% solid. I come from the UK where oil gets changed in cars annually or every 20k miles. Generally the engines are kaput after a relatively small mileage - 4 cylinder 100k miles. I spoke with a UK mechanic who religiously changed his oil every 3k miles and was able to get 300k miles out of a 4 cylinder engine (taxi driver). He was a super practical guy & his word/experience was good for me. Fingers crossed - teenage daughter just headed for school in the LR2, no doubt hitting 80mph on the way......
Thx for the feedback - sincerely appreciated
Jim
Jim
guy (05-09-2022)
Reminds me, I did some consulting at Aramco. The people I met changed their oil every weekend by driving into the desert….
;-) Maybe we’re getting used oil, lol.
The routine I follow is 5K kms for oil. 25K kms for the peripherals, including power steering, brake fluid, coolant, diffs, PTU, etc.
And I’m on the 2nd engine!
flyingscot (05-11-2022)
Guy - I applaud your scrupulous regime (better than mine). I expect your engine (6 cyl) is going to last longer than mine (4 cyl turbo). What mileage & what was the failure mechanism for your engine #1....? (even more disappointing when you consider your fluids regime...)
Definitely staying away from Arabian sand with the LR2......
Thx
J
Thx
J
2013 model. its the ecoboost 4 cylinder. I got the dreaded camshaft out of position one frosty morning (-40, not including windchill) and didn’t use the block heater. Stupid.
Never doing that again.
Actually, gazelle on the bbq (South Africa) is better! ;-)
Does the aux heater also provide cabin heat while it warms up the oil pan? I was reminded of this option when I plugged in my car into SDD to trouble shoot the A/C and reset all the old trouble codes.
