LR2 code p0087
Ok thanks for that, much appreciated I will try the test next time it gets into that state. One more thing to note, the fuel tank was as low as I have had it in a while (right on E) and I hadn't opened the cap since it was full to the brim and much colder out. Just something that may be note-worthy.
That FOB issue only ever seemed to happened when the FOB was not taken out then replaced for restart. Way back I told people it was a great security feature. hehehe.
But this makes more sense - almost along the same lines as the gas cap not being properly seated/reseated and rough idle.
Looks like the part number for the Evap Purge Valve is LR003489 for the 2010 LR2 HSE - I will get it asap and shouldn't be too hard to get to - down in front. I will hold off on the crankshaft position sensor.
Thanks again!!!
Thanks again!!!
Finally got the part up from upstate post-box into Ontario, and looks like a little more effort to get access. Question if you know, does the front bumper have to come off?
I notice besides the under-engine metal shield and light gray plastic tow hook cover( 2x twist offs) there is another black plastic cover surrounding tow hook (looks like 4x 8mm bolts).
Can I get access by removing that black plastic cover that surrounds the tow hook or does the bumper need to come off?
thx!
thx!
thx!
thx!
Oh, ok thanks! I was looking up more at the front of the engine(1/2 way up) which is obstructed by that black plastic cover (while I was doing an oil change) but I will get back under and recheck, but up on ramps this time for better vantage or viewing point.
Thanks again!
Thanks again!
Remove the steel protection plate that is under the Engine/Transmission
Then remove the intake tube
Then remove the Electrical connection and Purge Line from the valve (green objects on the right side)
The next thing to remove is the Vacuum hose that connects from the Purge Valve to the intake manifold.
That's the hardest part.
I suspect that the mechanics buy a new Vacuum Hose and just cut off the old one.
Reassembly is the reverse of disassembly
Good Luck
Paul
Good Luck
Paul
ThorInc (05-09-2023)
