LR2 coolant leak
Ok, your dealership is in the wrong then.
It was not a recall, however it was a service action. Service actions show up on the DDW, and are supposed to be taken care of when the vehicle is in for service, not like a TSB where it is more of a reminder to the tech of what could be causing an issue. This one particularly has 4 options to it when preformed, the first two being to check to see if it is the new style hose, and go no further if it is. This basically means that it is not a 'fix if there is a problem' but fix it if it has not already been fixed.
Call your dealership, and ask them if the Q081 is open in your DDW, all they will need is the last 8 of your VIN, and you can call any LR dealership.
If it is, I would be speaking to the manager at the dealership that you were using, as it should have been done(unless you declined it being done due to time, ie wanted your vehicle back asap and didn't want the extra 15 minute repair handled)
Unlike a recall, a service action does expire, and does not go beyond the warranty period, so from LR there is nothing, however it does seem that your dealership did not properly handle the situation, which LR did handle correctly by pretty much saying if you ever took an LR2 to the dealership while under warranty, your hose should have been checked to be correct, and replaced if it wasn't, despite it leaking or not.
So, umm how difficult is it to replace a fuel sending unit on an lr2?
Resistance on the senders can be checked via the access panel under the RR seat, which is easy to access, and there have been issues with the connector to the pump/senders being loose or under strain causing erratic readings.
Not the most fun, fuel tank needs to come down.
I spoke to my local Land Rover dealer today. He said a service action such as Q081 wouldn't show up in their DDW because that only lists recalls. After a bunch of back and forth, he said they would pay 50% of the repair which is replacing the alternator. Should I believe them that this was not something that they missed?
Dave-
Thanks for all your help and knowledge on this. I called Land Rover USA and gave them my VIN and they told me that there were no open service actions or recalls on my car. When I told them what you said about it dropping off when the warranty expires and giving them the # Q0-81, they confirmed that this should have been fixed while in for warranty and was somehow missed. They have opened an investigation case into this for which I asked them to pay for 100% of the repair since their neglect to check for this and fix it resulted in my alternator being damaged. We will see how it turns out. Thanks again.
ZMonet
06-24-2016 04:00 PM
MyRoversNameIsCarl
08-10-2014 09:22 PM
aguison
11-18-2012 05:15 PM
lipadj46
07-08-2009 07:41 PM
