LR2 Coolant Reservoir Tank Cap Separation
Old Nov 28, 2025 | 07:50 PM
LR2driver's Avatar
Default LR2 Coolant Reservoir Tank - Cap Separation
Upon removing the cap from the tank, I noticed the inner part of the cap (the sealing part) was left in the neck of the tank. It separated from the outer screw-off portion for some unknown reason. I pulled it out of the neck with pliers. I don't recall if this was an OEM cap or an aftermarket cap, but I know that I replaced it years ago on a preventive maintenance basis.
LUCKILY, I had a spare cap on hand, the one that I previously replaced. It's usable and avoided downtime since a cap is necessary.
I performed a quick online search and discovered this is a common problem for plastic caps on many car models. So it would be a good idea to have a spare.
june82000
Aug 4, 2015 05:59 PM
Echoman
Oct 10, 2014 08:54 PM
seedsntrees
Jun 13, 2013 04:14 PM
russburcham
Feb 13, 2013 07:50 PM
JBEGIN
Nov 8, 2009 07:03 PM
