Manifold Vacuum Test using Gauge (2008-2012)
My Torque app shows the Vacuum from the MAP sensor at 20.67 in/Hg at idle. The manual says the normal range is 15 - 22.
This exercise is purely informational. Just want to get a manual reading to compare against the computer reading, and have the practice of knowing how to measure it if I ever suspect the MAP sensor is faulty.
Now on to Turkey and pie. Happy Thanksgiving!
There are many ways to troubleshoot a faulty MAF , one of them is to monitor the fuel trims .
MAP sensor, not MAF. The challenge in replacing the MAP is not the cost of the item but the difficulty to perform the task for a component that is hard to access as well as the risk of breaking the connector. In this case, a proper diagnosis is better than the parts shotgun.
