OBD2 PID codes for LR2
Old Jun 22, 2020 | 08:40 PM
LR2driver's Avatar
Default OBD2 PID codes for LR2
I'm trying to display the transmission fluid temperature using my OBD2 scanner. Does anyone know the PID code I should enter? Or even better, does anyone have a list of PID codes for the LR2?
Old Jun 24, 2020 | 06:49 AM
ThorInc's Avatar
Been here before without any success.......the stock PID and a custom PID I got from a forum member elsewhere kept giving me the coolant temp. I use the Torque Pro app and I even emailed the developer without success. I purchased an Icarsoft LR2 2.0 scantool because you need transmission temp to set the proper level and it does not provide it (their customer support sucks BTW, reported problem as the tool was designed & marketed for DIYers and Land Rovers but after initially providing them software feedback, total "crickets") I don't recommend Icarsoft. I should have just used an external temp gun and skipped the Icarsoft scan tool.
Subbed JIC someone has the correct PID and are willing to share.
Old Jun 24, 2020 | 11:25 AM
flybd5's Avatar
[Murphy nods.]
Old Jun 24, 2020 | 02:09 PM
LR2driver's Avatar
I have the Torque Pro app as well and the Trans Fluid Temp displays exactly the same as the Coolant Temp, just as you indicated. Makes you wonder what you can believe.
An external IR temp gun pointed at the pan would be good enough for a drain & fill service. But I want to monitor the temp while driving to check the health of my tranny.
It's possible the Trans Fluid Temp is in a different network than the standard OBD2 PIDs which are focused on emissions. These PID codes seem to be a dark secret that the car manufacturer's don't want to share.
Old Sep 12, 2020 | 12:53 PM
LR2driver's Avatar
I just purchased a new code scanner (Autel MaxiDiag MD808 Pro) as an upgrade to my basic OBD2 emissions scanner. This model is advertised to read all modules/codes from all vehicle makes (except the most exotic). I purchased this unit so I can use it on family cars which are a variety of brands.
I scanned my LR2 and was surprised to discover it has 27 modules! This includes all the major ones (ABS, Transmission) plus others for smaller things like the stereo and power seats.
My first interest was to check the Transmission Fluid Temperature which this scanner supports. It's in the Transmission module which my basic scanner cannot access. When the vehicle is warm, the fluid temp lingers around 165 degrees F, which sounds normal.
It's always good to know what normal looks like so you have a baseline to compare against when you're troubleshooting a problem in the future.
Old Sep 12, 2020 | 01:05 PM
flybd5's Avatar
The LR service manual says the normal transmission fluid temp should be between 50-60C (122-140F). However, in general the recommended operating temperature range for transmission fluid should be between 175-220F. Anything higher and you start to turn the fluid into varnish and the transmission will soon give up the ghost if you run it that way for very long.
Old Sep 12, 2020 | 01:13 PM
LR2driver's Avatar
I have a PDF copy of the LR2 service manual, but I could not find the normal temp range. What is the title of the section where you found it?
Old Sep 12, 2020 | 05:51 PM
flybd5's Avatar
Search for "Transmission fluid temperature". You'll get several hits; I found it in the section entitled "Automatic Transmission/Transaxle - Diagnostics"
Old Sep 12, 2020 | 11:17 PM
LR2driver's Avatar
Yep, I see it. This is the temp range to check the level. I suspect they don't want you to check the level when it's hotter because the fluid may expand and give you an inaccurate result.
The normal operating temp is likely higher, as you indicated and I measured on my vehicle (although they don't specify in the manual).
Old Oct 29, 2021 | 10:09 AM
moontan's Avatar
PID: 22df0a
Long Name: Anything you want
Short Name: Same as above
Min Value: 0.0
Max Value: 100.0
Scale Factor" x1
Unit Type: deg C
Equation: A*256+B
OBD Header: 7e1
Enjoy!
PS: It may also help to deselect Using Separate dasboard under Vehicle profile.
LR2driver
LR2
Sep 16, 2019 10:19 PM
kind16
LR2
Sep 15, 2019 01:00 PM
drzjoint
LR2
May 21, 2009 07:04 AM
05LandRover
Freelander
Dec 18, 2006 04:17 AM
