OEM trailer hitch
Did some rudimentary research on this as I bought mine used and the hitch was already installed & configured when I bought it. To my knowledge, there should be a pre-installed module located in the driver's side of the trunk (inside the panel). Best to get as close to a plug and play setup compatible with this module. In addition you will need to activate the trailer feature in CCF(car config file) with SDD or use an iidtool or the like to disable the reverse sensors once a trailer is attached.
Maybe a junkyard?
Maybe a junkyard?
