Service
Old Apr 19, 2026 | 02:33 PM
Charlie49's Avatar
5th Gear
Lightbulb Service
Just bought a 2015 LR2 with only 18,585 miles. The mileage matches the CarFax report. Oil changed yearly, brake fluid flushed a changed twice and maintenacne inspection performed yearly. Any suggestions as to services that should be done?
Old Apr 19, 2026 | 10:11 PM
LR2driver's Avatar
I would start with a thorough multi-point inspection before services. Time can be a greater killer than mileage. You might be driving on 11 year-old tires.
Old Apr 20, 2026 | 01:11 PM
merlinj79's Avatar
Replace coolant, if not documented (there are discussions on this site as to what to use, but OEM or DEXCOOL is fine). I'd probably replace the coolant reservoir too, the level float will fail over time and indicate low coolant when it's not low.
Replace transmission, rear differential, Haldex (AOC) and front PTU fluids. LR OEM schedule does not specify these, but they are very important to do every 50K or sooner. Since it's been 10+ years, I'd replace them even with the low mileage. The driveline is actually Volvo, so many parts and fluids are much cheaper if you shop Volvo vendors (need to research correct part numbers for 2015). Worth noting that Volvo *does* specify mx schedule for these items... LR just expects you to buy a new vehicle when they fail.
Transmission Fluid: AISIN (this is OEM for our transmission, google for correct spec for 2015).
PTU Fluid: OEM (cheaper from Volvo vendors)
Rear Diff Fluid: These are prone to bearing failure, I'd use quality synthetic 80W90, not OEM (I use AMSOIL Severe Gear)
AOC (Haldex) Fluid and Filter: Volvo (available in a kit)
Old Apr 20, 2026 | 02:29 PM
Charlie49's Avatar
5th Gear
Default Thank You
WOW, I really appreciate the detailed recommendations, including parts and supplies. Have a great day Merlin.
Kevin Chambers
LR2
Apr 26, 2024 03:03 PM
qandaappraisals
LR2
Mar 2, 2022 12:50 PM
Kevin Chambers
LR2
Apr 8, 2020 09:02 AM
spapailias
LR2
Dec 11, 2010 11:34 AM
Joyce
LR2
Jan 25, 2008 05:50 PM
