Speaker issue with aftermarket amp and head unit
Old Feb 3, 2025 | 06:35 PM
Brickshh's Avatar
4th Gear
Default Speaker issue with aftermarket amp and head unit
The person before me removed and bypassed the oem amp and replaced the head unit. Now the only speakers that seem to work is the front driver and the rear subwoofer. No mater what combinations I use (of course all the wires are the same colors) thats the only speakers that work. Am I missing something somewhere?
Old Feb 4, 2025 | 03:22 PM
guy's Avatar
guy
Who knows what hacks hava been done... I quite like the oem solution. It works. It sounds great.
Truly, to do it right, all the wiring should be replaced.
I assume you have some electrical background and you have not disturbed the impedance by wrongfully wiring it up. And that your new amplifier actually works on all channels.
Old Feb 6, 2025 | 05:07 PM
Brickshh's Avatar
4th Gear
I am starting to think I have no clue about electronics. What doesn't make sense is that even if I plug in the right front speaker to where the left front speaker is working the right doesn't work.
Old Feb 6, 2025 | 05:57 PM
LR2driver's Avatar
Those speakers are probably 4 ohms, but you can measure the resistance of the working left speaker with a multimeter to verify. Then measure the resistance of the non-working right speaker. If it's an open circuit, or a much different resistance than 4 ohms, you probably have a wiring or connection issue to that speaker, or the speaker itself is bad.
LRDISCOVERY2
Audio/Visual Electronics
Sep 10, 2014 09:42 PM
Hyakku
Apr 23, 2012 11:39 AM
turf63
Jul 12, 2010 10:48 PM
turf63
Jul 10, 2010 11:33 AM
sailorcolin
Apr 25, 2007 07:54 AM
