Trans Valve Body Solenoids
Old Jun 1, 2024 | 09:04 AM
flybd5's Avatar
British car with Swedish engine, Japanese transmission and Ford TCM.
Old Jun 1, 2024 | 08:09 PM
LandyTires's Avatar
I'm actually messing with it right now, and it won't start because it's stuck in reverse. I know the solenoid only has a current of 0.2V compared to the other solenoids in order, which all have 1V
It's the top one but i also noticed yesterday that, while on, they can get pretty warm but it alone was cold, even while plugged in with accessory mode on
Old Jun 1, 2024 | 08:16 PM
flybd5's Avatar
Bad solenoid coil?
Old Jun 1, 2024 | 08:22 PM
LandyTires's Avatar
I'm pretty sure, unless it's wiring but I know even less there
Old Jun 1, 2024 | 08:28 PM
flybd5's Avatar
It's almost always not the wiring. That's been my experience since I was working on Marine helicopters in the 1970's.
Old Jun 1, 2024 | 08:54 PM
LandyTires's Avatar
Ok. In that case, could you tell me to remove the solenoid? I don't need to take out the whole valve body, do I?
Old Jun 1, 2024 | 09:02 PM
flybd5's Avatar
It looks like you will have to do that. But it looks like the connector is not plugged into the solenoid. Did you disconnect it?
Old Jun 1, 2024 | 09:11 PM
LandyTires's Avatar
I did. I was using a scanner to try and figure out which one it was but couldn't tell on location so I was doing the unplug and check to see what I did method lol
Old Jun 1, 2024 | 09:12 PM
flybd5's Avatar
Well, I have never tried to do what you are doing, but looking at the assembly it sure looks like you have to remove it to get to the solenoid mounting on the other side. Your mileage may vary, though.
Old Jun 1, 2024 | 09:16 PM
LandyTires's Avatar
What do you mean mileage? The car's sitting at 182k miles
And I was afraid of that. The way it looks, do I need to remove all the bolts around the perimeter of it or just the larger ones. The smaller bolts look like they may hold the valve body assembly itself together.
