Transport mode???
Transport mode???
Hey. Lookit what I found in the Service Manual.
Transport Mode
All new vehicles will be delivered from the factory in transport mode. Transport mode replaces the traditional transit relay
and inhibits a number of electrical systems and features to eliminate quiescent drain from the battery during delivery.
When the vehicle is in transport mode 'transp' will be displayed in the instrument cluster odometer.
To remove the vehicle from transport mode, the Land Rover approved diagnostic system must be connected during the
Pre-Delivery Inspection (PDI). For more information, refer to the PDI manual.
What the heck? Is LR admitting that the parasitic draw on the battery is a FEATURE and not a bug?
Transport Mode
Just to go a little further - many manufacturers have a transport mode, since shipping times can be in the 'months' time frame. Another part of the manual tells the LR dealer how long a car can sit, after PDI, without charging and that the battery must be replaced if the time frame is not followed and the battery goes flat! Shows how critical it is for the battery to be put on a maintainer, or disconnect, if we are going to leave the LR not running for an extended time.
Some Audi dealers use solar chargers to help maintain the battery while on the lot.
No rewrite is necessary. Modifications to the code would be required. Big difference.
Top Post Battery Disconnect Switch 12V / 24V 250/750 Amps Knife Blade Isolator Power Cutoff Switch for Marine Car Boat RV ATV (Negative, Vertical)
I installed one of these which I bought from Amazon. Of course, if you are going to use it, the manual key must be used to lock driver's door. I would post a link but my tablet won't let me from the Amazon acct....
I have used it many times, more times just working on the LR2.
The following 2 users liked this post by ThorInc:
flybd5 (08-10-2023),
flyingscot (08-19-2023)
