Turbocharger failure
99000 miles, turbo failed, it’s being replaced. I do have a question, guess maybe a fishing question. My car was rear ended 3 months ago, 4000.00 damage, all repaired, the muffler had to be replaced, ( Land Rover muffler, came from England, took 2 months), any way, is there any possibility that the collision damaged the turbo? Every thing worked well after the car was repaired, never did smell gas, no smoke, no signs of turbo failure till it quit, then there was a loss of power and loud noise like major vacuum leak
ThorInc (12-23-2021)
According to Garrett, the company that makes a pisspotful or turbochargers for many applications, less than 1% of turbos fail because of manufacturing defects. Most failures are caused by the three ‘turbo killers’ of oil starvation, oil contamination and foreign object damage. More than 90% of turbocharger failures are caused oil related either by oil starvation or oil contamination. Blocked or leaking pipes or lack of priming on fitting usually causes oil starvation.
In other words, take good care of your engine's lubrication and you will be less likely to have to deal with a turbocharger failure.
They did? There should only be one electrical part on the LR2 turbocharger, the wastegate valve, and that's a replaceable item, you can even find it on eBay. If so, why didn't they replace that instead of the entire turbocharger? That sounds sketchy...
guy (01-02-2022)
Another common issue on the earlier models of the turbo on the ecoboost engines was a crack in the casing. I wonder what would have been the cause for that?
I have read this thread twice and can’t seem to find a mention of the exact model of vehicle…
But due to some troublemakers… look what I found: https://www.dieselusa.com/garrett_ec...ochargers.html
sigh/. If I could only upgrade the engine…
