whistling noise at idle
I have Check Engine Light on with P0171 and P0174 and intermittent loud whistling noise at idle. It goes away with engine revs or oil filler cap/dipstick removals. I've been through many sites and learned that it could be related to PCV valve but I couldn't find any PCV valve thingys on LR2 sites. I now wonder LR2 even has PVC valve. Please help me with the issue. Mine is 2008 LR2 SE 87K miles on it. I don't know if it's coincident but I get the whistling noise after I cleaned the MAF sensor and relocated the air filter to resolve the codes. Thanks in advance
A common method for finding a vacuum leak is to introduce white smoke into the system (while engine OFF) and then watch where it comes out. Youtube has a lot of videos showing how this is done.
I suggest you call around to your local shops and ask them if they have a smoke machine and how much they charge for a vacuum leak smoke test. Please post back and let us know how it goes.
