whistling noise at idle
Old Feb 25, 2015 | 03:18 AM
BlueSky LR2's Avatar
6th Gear
Default whistling noise at idle
I have Check Engine Light on with P0171 and P0174 and intermittent loud whistling noise at idle. It goes away with engine revs or oil filler cap/dipstick removals. I've been through many sites and learned that it could be related to PCV valve but I couldn't find any PCV valve thingys on LR2 sites. I now wonder LR2 even has PVC valve. Please help me with the issue. Mine is 2008 LR2 SE 87K miles on it. I don't know if it's coincident but I get the whistling noise after I cleaned the MAF sensor and relocated the air filter to resolve the codes. Thanks in advance
Old Feb 26, 2015 | 12:56 AM
LR2driver's Avatar
What did you mean when you said you "relocated the air filter"?
Old Feb 26, 2015 | 01:45 AM
6th Gear
Sorry for my bad wording. I just pull the filter and rotate 180 degree and put it in.
Old Feb 26, 2015 | 03:16 PM
LR2driver's Avatar
Understood on the air filter repositioning.
Did you clear the codes so the only remaining problem is the whistling?
Old Feb 26, 2015 | 05:02 PM
6th Gear
I've erased the codes several times but not able to clear it yet.
Old Feb 26, 2015 | 06:42 PM
LR2driver's Avatar
It may be a vacuum leak. If the whistle noise started after you cleaned the MAF, you might not have put it back together with a tight seal. With the hood up and engine running, try to listen where the whistle noise is coming from.
Old Feb 27, 2015 | 12:41 AM
6th Gear
I've learned that it might be a vacuum from the crankcase according to a BMW forum. I'm trying to locate the PCV valve for LR2 so I could try to clean/replace it. I thought I could find the related thread for this forum. My LR2 has no issues so far other than the noise and CEL.
Old Feb 27, 2015 | 01:51 PM
LR2driver's Avatar
I don't believe it has a PCV valve. Please let us know if you learn differently.
Old Feb 27, 2015 | 04:45 PM
6th Gear
Okay then. Let's forget about the pcv valve thingy.
I have the loud whistling noise at idle. Two mechanics so far couldn't figure it out where it coming from. It disappears when I pull the engine oil cap or dip stick. What do you think the cause?
Old Feb 27, 2015 | 07:34 PM
LR2driver's Avatar
A common method for finding a vacuum leak is to introduce white smoke into the system (while engine OFF) and then watch where it comes out. Youtube has a lot of videos showing how this is done.
I suggest you call around to your local shops and ask them if they have a smoke machine and how much they charge for a vacuum leak smoke test. Please post back and let us know how it goes.
