05 Land Rover LR3 Very poor Gas milage
Old Nov 13, 2023 | 07:43 AM
  #21
vito13's Avatar
Originally Posted by kels83
eBay. Authentic ZF kit under product number 1068 298 044. Also replaced the metatronic sleeve (known to leak and was pulling it out as part of the job), ZF valve body sleeves, and transmission plan with the trans filter all for the ZF 6HP19 transmission. I also needed 5 liters of ZF Lifeguard 6 fluid but understand Maxlife works for a fraction of the cost. Total was about $650 US with that expensive fluid and it took about 5 hours.
I went with a steel trans pan because it has a replaceable filter and is easier to install/remove. The ZF transmission pan requires removing a crossmember and jacking up the engine/trans because the filter is built in. I followed guides on this site to hack saw the plastic neck of the old filter so I didn't have to do all that, then swapped with an "upgrade" pan + separate filter. Much easier, but a really messy job no matter the parts. I have to do it again on my 2011 range because it takes a few seconds to get into reverse. Problems getting into gear are usually the $50 valve body sleeves, but might as well swap the rest while doing the job. That fluid is liquid gold.
Thank you for the details, I'm ordering everything and do the transmission service.
Fluid is expensive yes, still looking around for best place to buy it here in Canada.. other parts that you stated as easy to find only. Also check a very good video o youtube where I could have a visual look at parts you are talking about. Thank you
Old Nov 13, 2023 | 07:47 AM
  #22
vito13's Avatar
Default Update on P0171
After checking all connections on air intake, swap another MAF sensor and replace air filter ( just because had one laying around)
Engine light came right after drove a couple miles but no p0171, instead I got:
- P0137 and P0138
- P0170
For my surprise!!
DarkHorseMC
Aug 6, 2022 12:28 PM
n1keaddict
Mar 5, 2022 08:50 PM
LR3 Bros
Mar 2, 2022 07:18 AM
Porksquid
Sep 14, 2017 09:10 AM
axg1040
Jul 8, 2008 06:55 AM
