06 lr3 hse
Old Sep 20, 2014 | 05:04 PM
  #21
jafir's Avatar
On my previous rover a 2003 D2, I had silver and black center caps from a RRS Supercharged.
Old Sep 20, 2014 | 09:13 PM
  #22
TOM R's Avatar
Is there a rave download for lr3 available?
Old Sep 20, 2014 | 09:33 PM
  #23
jafir's Avatar
Not exactly. There is a copy of the service manual that someone took a lot of effort to print out from an online service manual, probably land rover's topix service. It seems to be a fairly old revision and I've found some stuff in it that is just plain wrong. But it's better than nothing.
I'll see if I can find a link to it when I'm not on phone.
Old Sep 21, 2014 | 06:48 PM
  #24
TOM R's Avatar
Pulled the drivers can cover here is a pic, drove it to dads bout 1/2 mile this noise is definitely a clacking, even cranking with the cover off sounds like when the exhaust came lobs hit the valves on that first cylinder, I do not see anything obvious nothing looks broke or scarred or discolored from overheating a part
Chains feel tight up top but no real clue what I am looking at never worked inside this type of engine before need some real guidance please, I plan to keep pulling it apart to access the timing set
Here is a pic of the area I believe the noise is coming from
Old Sep 21, 2014 | 08:42 PM
  #25
thorgal's Avatar
Tom, shoot me an E mail via PM . I can send you a workshop manual, that many of us bought some tim a go off ebay. It is not a lot , but at least it is a start and provides some valuable info about LR3 s.
Old Sep 22, 2014 | 09:54 AM
  #26
TOM R's Avatar
thorgal got it thanks
compression test this morning had about 160 across all cylinders
spark plugs are definitely beat, look normal just been in there a lot of miles post pic later, all plugs look the same
I am obviously buying new ones since I need em either way, current plug
NGK 1FR5N 10
Old Sep 23, 2014 | 09:13 PM
  #27
TOM R's Avatar
well no good news, had a rover dealer tech I know come by and listen to it, he has no clue, never heard that sound but thinks its deep in the engine possibly a cracked wrist pin s it is not timing set noise or lifter or vvt, it just baffles him cause it runs so smooth but is so loud and my compression test was good
so guess back to square 1 my options are pull and start tearing down the engine, try to find a used one at a good price or just sell it try to break even and start over
he does figure I can pull and fix the engine for 2k more or less since I am doing the labor unless it ends up being trash
Old Sep 24, 2014 | 05:26 AM
  #28
taylor15's Avatar
Wow that's bizarre! I hope you can find resolution, I was looking forward to following this build as I have your 98. Good luck!
Old Sep 30, 2014 | 08:19 PM
  #29
TOM R's Avatar
We scored an 05 lr3 with 50k on it so this will be parted or sold
Old Sep 30, 2014 | 09:00 PM
  #30
houm_wa's Avatar
only 50k is good! Still time to save the diffs and change the tranny fluid and all that stuff.
