06 lr3 INTERESTING EAS FIX???
Old Mar 16, 2013 | 09:59 PM
Rover Family's Avatar
7th Gear
Good info. Where did you purchase the GAP Diagnostics EAS tool?
Old Mar 18, 2013 | 07:45 AM
jmcmurra's Avatar
Got mine from Justin @ lucky 8 LLC
Old Mar 26, 2013 | 03:55 PM
Xrover's Avatar
Interesting.
I am having a similar problem. My front suspension slowly drops when parked. Mine will drop equally (Both front springs). It only takes a few hours after parking for it to slowly drop about 2 inches. During this time there is no EAS activity. I think I might have a link valve leak.
Old Apr 2, 2013 | 04:53 PM
bjwhite's Avatar
Xrover,
I had both front sides settle down overnight, and a couple nights they would be at the bump stops. Over this past weekend, I replaced the front valve block with a new one and all is well. It's high and proud in the mornings now.
The block was $170 or so from Miami British....British Atlantic was sold out for now....
Old Apr 2, 2013 | 05:37 PM
Xrover's Avatar
Originally Posted by bjwhite
Xrover,
I ended up pulling the F26 fuse in the engine compartment to disable the EAS system. I then jacked up the front end with a floor jack. I removed the front right fender splash well and sprayed soapy water on the block. I found that the in/out fitting was leaking. I also noticed that all three air lines were not fully seated in the fittings. I loosened each one and let the air bleed out.
I removed all the hose fittings and removed the block. I did a visual inspection of the block then reinstalled all fittings. I then lowered the vehicle, reinstalled the fuse, turned on the engine and let the system charge back up. I sprayed the block again with soapy water. No leaks !!
It's been a few days and all is good. PROBLEM SOLVED!
80% of the issues I've had with my LR3 have been due to loose connections.. My guess is dealers probably know this but would rather say a part is bad and and make money on the labor and new parts.
Old Apr 9, 2013 | 01:55 PM
RoverMasterTech's Avatar
Wow, So you're saying English cars have bad build quality, and dealers are out to bleed every penny out of you? You're like a genuine Matlock.
Yikes!
Apr 9, 2014 09:33 AM
novistar
Feb 14, 2009 10:37 AM
novistar
Feb 11, 2009 06:32 PM
novistar
Feb 10, 2009 10:35 AM
simjack
Oct 12, 2008 10:24 AM
