0W20 Oil
I'm going to give the new oil (5W-30 synthetic) about 4000 miles and have that tested too. If the levels are still high, something is wrong.
Hopefully they just used crappy oil of the wrong viscosity and all will be back to normal with proper oil.
Was it used or new motor? Did you tell them this isn't the original motor? Has the oil been changed since the new motor was put in? Just guessing, but I'd say the numbers are unusually high from the newness of the motor. If new, probaly just "break in" but if a well worn used motor, there could have been surface rust on items like the camshaft that wore off when started for the first time in who knows how long.
Good for you having the oil analyzed. Stuff like this is why everyone should at least know how to change the oil and DIY every time. Just use the standard Castrol Edge 5w-30 from now on. If you use an additive when you change it next try the BG MOA stuff (formerly BG109?), I had decent luck with it. Please do post back if you have the next set of oil analyzed. More data is useful for everyone!
I have never had the oil changed on any of my cars by someone else. Too much opportunity for idiots to brick a motor over something so simple yet so critical.
I'm definitely analyzing the oil from here on out as I do with my other car as well. It's really only useful if you do it every time to identify trends.
Here are the results in case you guys are curious:
![](https://cimg7.ibsrv.net/gimg/landroverforums.com-vbulletin/730x557/2017_03_17_112705_9b94b43f54956aa7901d7e5be21bf210bb75d8f7.jpg)
disco12
03-07-2006 01:10 AM
