180 degree thermostat
Old May 8, 2023 | 06:24 AM
keninnc's Avatar
Default 180 degree thermostat
Has anyone replaced the 190 degree thermostat with a 180 degree version?
Old May 9, 2023 | 09:13 PM
Best4x4's Avatar
Is there a 180F version for the 4.4L V8?
Old May 10, 2023 | 11:01 AM
keninnc's Avatar
I am trying to find one and hoping someone else has found one that will fit the thermostat housing.
I’ve found a couple that are close but don’t fit.
My LR3 is running fine, I’m just curious what the engine temps would look like with a 180.
Old May 10, 2023 | 09:17 PM
elemental_garage's Avatar
Is there a reason you're wanting to drop temps if it's running fine?
Old May 10, 2023 | 10:51 PM
tracyc's Avatar
I'm curious about that too. Unless you have cooling system or engine problems, this vehicle has no problem maintaining rock solid, steady coolant temperatures.
Old May 11, 2023 | 06:16 PM
keninnc's Avatar
I’m just curious.
I’m coming from the D2 world where Land Rover intentionally ran the engine for better emissions.
I believe a lot of modern engines, not just Land Rover run hotter for emissions but may be to the detriment of the engine in the long term.
The 4.4 V8 seems to be one of Land Rovers best engines but I’m still curious if any one had replaced the thermostat with one that opens earlier.
zuke
Nov 7, 2019 08:22 AM
metzdmichael
Jul 11, 2018 12:12 PM
huggi
Oct 12, 2016 11:09 AM
DiscoRover007
Aug 13, 2015 10:38 AM
