19 inch wheels & going to 18 inch
Old Jan 11, 2011 | 07:34 PM
Joebern's Avatar
6th Gear
Default 19 inch wheels & going to 18 inch
I have a 2008 LR3 HSE with 19 inch wheels and want to go to 18 inch wheels. Will I have any problems? Brakes an issue? I think I want the Cooper Zeon LTZ ties. Any suggestions on good wheels?
Old Jan 13, 2011 | 05:09 PM
Xrover's Avatar
I ditched my 19's on my 06 LR3 HSE. I put on 18" Black Dub Drones with Hankook Dyna Pro AT/M 's. I have not had any braking or tire rubbing issues.
I do off road it and they have never rubbed
Old Jan 14, 2011 | 09:53 PM
Joebern's Avatar
6th Gear
That looks great! Thanks!
Old Jan 15, 2011 | 09:22 AM
jimbiram's Avatar
I took off my 19's almost 4 years ago and bought 5 new 18" LR wheels from dealer. On my 2nd set of Cooper Zeons and very happy. The Zeons are a very sticky tire on rock, yet they last a long time. Last set was 47k miles, and there was still tread left. Sidewalls are a little soft, so you have to run the fronts 5 psi higher than factory and rear a couple psi higher. Watch the sidewalls on rocks and pick good lines. I've never had a trail tire failure, all on the highways from crap bouncing around.
Old Jan 26, 2011 | 01:27 AM
hiyabrad's Avatar
4th Gear
Why do you go to a smaller wheel? Is it for clearance in the wheel well?
Old Jan 26, 2011 | 03:30 PM
Xrover's Avatar
The reason I went to 18's is because there are very few off road tire options available in 19" Also tires for 19" wheels are more expensive. The 18" size has unlimited options for tires and the prices are much more affordable.
Another reason is with an 18" wheel, you get a tire that has more sidewall to it. This gives you more rubber between the wheel and the road which gives a softer ride and a far less chance of bending a wheel from potholes. The diameter of the 19" wheel with the thinner tires is still about the same as an 18" wheel with the taller tires so wheel well clearance is still unchanged as is your speedometer.
I am sure other members have additional comments but those are mine.
Old Jan 26, 2011 | 08:51 PM
Joebern's Avatar
6th Gear
Xrover gave the same answer I would have.
Old Jan 27, 2011 | 05:43 PM
hiyabrad's Avatar
4th Gear
Thanks Xrover! Makes perfect sense.
Old Jan 28, 2011 | 08:52 PM
Johnson Rods's Avatar
LR Forum Vendor
I went to 18 inch rims in 2006 to have more options. You will have no problems doing this. Currently I use the 275-65-R18 GY MTR with kevlar. This has been an excellent tire for me and I would purchase it again.
For an AT, I would recommend the GY Silent Armor AT. I do have a listing of other options and the approximate cost for each based on rims size. You should be able to find everything here as the list is current:http://johnsonrods.com
Good luck. Let us know which tire you choose.
Old Jun 10, 2011 | 01:57 PM
waltkrey's Avatar
Default 19 inch 6 spoke lr3 wheels
Need a set of four 19 inch HSE LR3 wheels, have a set of 18 inch 5 spoke wheels
