2006 LR3 4.4 Code Question
Old Jul 24, 2023 | 02:40 PM
denver6161's Avatar
4th Gear
Default 2006 LR3 4.4 Code Question
I've tried searching for more information on this issue but I'm struggling to find anything specific. Sorry if I missed it in another thread.
I recently started getting a check engine light on my 2006 LR3. Pulling the codes with the GAP tool shows a number of the common "phantom" codes as well as the one below:
  • P2451-00 (AA) Evaporative emission control system switching valve stuck closed
I don't have a lot of experience dealing with some of the emission control systems on this truck. Could this be related to the fuel cap or should I be pulling the evaporative canister or something else? Just curious if there are any other resources out there that I could use to track down the issue. TIA!
Old Jul 24, 2023 | 06:12 PM
DakotaTravler's Avatar
The EVAP system is simple yet annoying. In theory the valve is stuck closed because the system is not detecting a vacuum pull from the engine. The valve is on the passenger side behind the engine block. Not exactly easy to get at. They do indeed stick open/closed. Not sure if cleanable or if replacement is best.
Old Jul 26, 2023 | 08:43 AM
denver6161's Avatar
4th Gear
I appreciate the information. I was hoping it was something simple like the fuel cap but after a bit more research I'm realizing that there is a specific error message for that issue. I'll start poking around back there and see if I can at least easily identify the part.
Thank you
vanbadri
Jul 31, 2019 09:19 AM
Omorin34
May 31, 2016 12:38 PM
Big_Easy
Jun 24, 2009 01:15 PM
hendoc3
Apr 2, 2009 06:59 PM
