2006 LR3 frame question
Old Aug 26, 2020 | 03:41 PM
Flyun's Avatar
If they ain't rubbin, they ain't big enough
Old Aug 26, 2020 | 03:44 PM
prbeane's Avatar
8th Gear
Exactly! I want to get that piece out of the way so I can go a little bigger.
Old Aug 29, 2020 | 05:17 AM
Land_Rover's Avatar
So 265/65R/18 are the biggest tires you can get with a lift kit without rubbing while turning or having the wheel impact the fender while going over a bump. The problem is that you'll have to start trimming off the bumper too if you want bigger tires, as the tires will start rubbing on that and can easily rip part of the bumper off even at lower speeds.
Old Aug 29, 2020 | 08:22 PM
houm_wa's Avatar
Default Huh???
What "lift kit?"
Maybe @Land_Rover means for driving around town, using Access Height and all that. I run 275/65R18 tires without any lift and no rubbing in nominal conditions (see below).
Caveats: it will rub in Access Height around town. It will rub if on the trail and I don't use the IIDTool to raise it.
Old Aug 31, 2020 | 04:23 PM
prbeane's Avatar
8th Gear
I don't have any rubbing issues except on the right front when reversing and I am running 275 /65 R18 with a 2.5 lift. Thanks for replying.
prbeane's Avatar
8th Gear
Thanks for your reply.
Papag1313
Oct 8, 2019 01:48 PM
vanbadri
Jul 31, 2019 09:19 AM
Sparky909
Oct 9, 2010 11:34 PM
Big_Easy
Jun 24, 2009 01:15 PM
