265/70 R18 spare tire
Old Aug 20, 2016 | 08:59 PM
ericcooke's Avatar
Default 265/70 R18 spare tire
So I spent a couple of hours today trying to get a 265/70 R18 spare to fit up under my 2007 LR3...not to surprise anyone but it did not work. I removed the plastic heat shield thing and deflated the tire. Then I tried using a ratchet strap to compress the tire a bit more. This got me within 1/2 to 3/4 of an inch from success.
Has anyone managed to pull this off? I have this crazy idea of running two spares since we plan on playing around in Baja a lot. One under the vehicle and one on a tire carrier.
Another thought I have wondered about is mounting the spare inside the back like on the old Cherokees. Anyone tried that out? Not sure I want to lose the space though.
I am interested in what kind of crazy genius ideas you guys have thought up...
Old Aug 20, 2016 | 09:53 PM
cmb6s's Avatar
I got a 275/65r18 wedged up there, but I had to remove the heat shield and deflate the tire to around 8 psi. I'm just not sure I can see getting a tire with a 0.6" larger diameter in there. I mean, if you're dying to do it, get a worn tire and try it out, or maybe shave it down some...
Old Aug 21, 2016 | 02:48 AM
clarkritchie's Avatar
Before I got a tire carrier I carried a 275/65-18 vertically in the back. I was able to get it to hold pretty tight with two tie down points and a ratcheting strap. Not bomb proof but it never fell over! That new tire smell, however...
Old Aug 21, 2016 | 02:51 AM
PS - I didn't find gas to be an issue in Baja the last time I went. That said, perhaps an auxiliary fuel tank that fits into the spare tire well would be an alternative use of that space. I want to get one of these!
300TD auxillary fuel tank spare tire well - PeachParts Mercedes ShopForum
Old Aug 21, 2016 | 10:05 AM
ericcooke's Avatar
clarkritchie- I like that idea. A LOT. I was just talking about what to do with that space last night with my girlfriend. I feel like it is a waste to not use it for something. It could be nice to run an aux fuel tank instead of jerry cans. That's some good thinking outside the box.
Old Aug 21, 2016 | 10:08 AM
ericcooke's Avatar
Also- I may try the ratchet idea as a temp storage for the tire. I am guessing you just ran the strap from one tie down and the through the wheel to the other tie down?
We have a trip in 2 weeks and that will at least be better than lying flat in the back and trying to organize gear around it.
Old Aug 21, 2016 | 10:16 AM
Yeah, that works fine. I looped the tie down through the wheel twice, higher than the middle, kind of in the the 10 and 2 position. If you put your hand on it it'll rock side-side a bit but mine always remained vertical and never fell over. But I found the smell of the tire (my spare was new) to be pretty harsh inside... YMMV!
Old Aug 22, 2016 | 09:36 AM
RedRocks's Avatar
I'm wrestling with the same issue- what do yall think about a roof rack mounted spare tire set-up similar to this?
I like the look, but not sure if it's worth having the extra weight that high.
Old Aug 22, 2016 | 09:53 AM
ericcooke's Avatar
Roof rack mounted is my other option and I have thought about the weight sitting up there as well. Here is my thought- what are you using the vehicle for? If it is more of an overlanding set up then you will probably be carrying a lot up there anyway. Or if you put a RTT up there then that is even more weight. If you are going to be wheeling it on more technical trails then the top weight would be more of a concern.
From what I have been told you can "feel" the tire up there but I can't see the additional 60? 70? pounds (not sure what the exact weight is) making that much difference.
As an aside- I have played with the idea of storing the spare in the valley/storage space in the back and building a second floor over it. I think it would work well but it will raise the floor nearly a foot. I don't like that.
Old Aug 22, 2016 | 10:26 AM
cmb6s's Avatar
It's about 85 lbs depending on tire of course. I tried it for a little while, but it's such a PITA to haul that thing up on top of the car and such a pain to get it off that it just wasn't worth it for me. However, if it's your second spare, then it might be a good option. I didn't suggest earlier because I didn't see a roof rack or rails on your truck.
