About the Air suspension
I receive a lot of questions on how the air suspension system works and its features. Here i put them all together in an easy to read post to clarify any doubts. Did you know you can program your remote to adjust the air suspension? Did you know about the 5 suspension modes your car has? All in one place. any questions please comment
Here is the link:
Land Rover Help!: Land Rover LR3 Air suspension
Here is the link:
Here are links to some of his suspension videos but check outs his playlist, he has a ton of videos.
RSW Solutions - LR3 Air Suspension Calibration:
Discovery LR3 - How to Find Air Leaks:
Discovery LR3 - Arnott Air Spring Install:
Discovery LR3 - Depressurize Air Springs:
Looks like he also owns or owned a Disco and RR so he has videos for those as well.
He has written software to be a 'lite' version of the handheld scanners that cost $500. I purchased it for $149 and it's great. I've been able to put the car in tight tolerance mode, adjust height calibration, see o2 sensor readings and other li've data, check steering wheel angle reading. He has a function to reset parking brake and to deflate / inflate the suspension.
I can't do updates to the ECU if/when I have to upgrade the compressor, can't reset the steering wheel angle if needed (only view the angle), and maybe some other thinks that the iidtool would do, but I've sure gotten my money's worth out of it
FORD Land Rover - 4Dcan Diagnostics
fastrx7man
01-28-2012 12:49 PM
catchthebig1
09-24-2010 11:57 AM
tripz
01-04-2007 05:58 PM
