Ac Delco Water pump
Old Jan 8, 2024 | 02:06 PM
BorrisLr's Avatar
5th Gear
Default Ac Delco Water pump
Hi, I am new to the forum, though I have been reading it for years. Have 2008 LR3 4.4 about 123k, owned since 2010. Recently, I was about to replace the water pump and ordered ac delco one after reading numerous reviews. Noticed. once I got to it, that there is less bolt holes on it. Ac Delco has 5 and normal pump has 7. I checked the water pump online and it is the correct model from Ac Delco. Decided to button up everything until I checked it out. Any feedback or experience? Greatly appreciated.
Old Jan 8, 2024 | 11:16 PM
P-Bod's Avatar
The AC Delco pump is a single piece body vs. the other two-piece pumps. Two of the bolts on the two-piece pumps only hold the halves together and do not bolt through to the engine block.
Old Jan 9, 2024 | 12:27 PM
BorrisLr's Avatar
5th Gear
Hi P Bod, thank you for the quick reply. I looked it up this morning and you just corroborated my suspicion. I will be installing the pump today. Now that i have been in it once before, it will be a breeze to do it. Thank you again..
Old Jan 10, 2024 | 05:48 PM
DakotaTravler's Avatar
Make sure you lubricate the o-ring that it comes with. I thought I did with mine and STILL pinched it.... So take care in installing it.
Old Jan 11, 2024 | 12:54 PM
BorrisLr's Avatar
5th Gear
Oh I already put it in. It went fine. But I could see how that would be really helpful. Good tip.
pgoodrich
Jun 14, 2022 09:27 AM
GBR.R
Aug 16, 2020 07:29 AM
ewbourne
Jan 16, 2015 08:53 AM
richard forsyth
Oct 22, 2013 08:48 AM
CUpgt
Aug 11, 2011 10:41 PM
