Aftermarket stereo and backup camera on my 06 LR3
Old Mar 23, 2020 | 05:16 PM
Codyhood's Avatar
5th Gear
Default Aftermarket stereo and backup camera on my 06 LR3
I have a aftermarket stereo that im want to put in my lr3. I cant find a wiring diagram to hard wire the system in. If anyone can show me where to go from here i would appreciate it!
Old Mar 23, 2020 | 08:17 PM
Globetrotter448's Avatar
If it was purchased for a Discovery, it should have come with a wiring kit that plugs into the original connections. You will need an Ariel kit to match up, available on eBay. Now if you are adding it to a HSE model that is a whole new ball game.
Old Mar 23, 2020 | 08:23 PM
Codyhood's Avatar
5th Gear
Mine is a 06 se with the fiber optic cables. Can i bypass the fiber optics?
Old Mar 23, 2020 | 08:38 PM
Not totally sure, but I think the basic radio does not use fibre optic cables. When I did mine I used the EONON double din radio (Android based) from eBay and it came with all bits, connectors and cables, had to buy the Ariel kit though to join the original to the kit supplied one. Reversing camera was one purchased from eBay and fits into the number plate light fitting. Running the cables for reversing camera was interesting
Old Mar 23, 2020 | 08:49 PM
Codyhood's Avatar
5th Gear
My double din is from wish so i dont know exactly what brand it is however i wasn't able to install the system because i bought the wrong dash instalation kit. Im going to try and find set of connectors for the stock wiring so i dont haft to hardwire it in .does anyone have a pacific place they buy aftermarket wiring harnesses from?
Old Mar 23, 2020 | 08:52 PM
Codyhood's Avatar
5th Gear
Old Mar 23, 2020 | 10:02 PM
You will need the brand so that wiring matches the radio connections plus will match the Discovery connections. Can you return it and get one for a Discovery as there are many out there
Old Mar 24, 2020 | 09:28 PM
loanrangie's Avatar
You will need the adapter harness that includes the fibre optic (MOST) cable, most Asian origin head units come with ISO plugs as standard so in most cases just the one harness is required.
If you have sat nav then it may or may not work depending on the harness kit you get, in the UK you would get a kit by Connects2 and in Australia i used the fitting kit by Aerpro .
Old Mar 24, 2020 | 09:39 PM
Codyhood's Avatar
5th Gear
Ok im in USA. Does anyone know where to get this in the states? Im very new to land rovers so learning as i go! However i love my truck and want to get this thing in.
Old Mar 24, 2020 | 09:43 PM
Google is your friend - depends on what came with it, any photo's as that may give us a clue. Front of product and rear of product may help. I used Aerpro for mine as well
