Air ride suspension compressor advise
Old Mar 25, 2014 | 09:58 PM
Burfyworld's Avatar
Post Air ride suspension compressor advise
Hello Everyone,i'm new to this forum and i need advise regarding suspension compressor.i will like to know if 2005 Land Rover LR3 suspension compressor will be compatible with 2006 Land Rover LR3, I need to change it on my '06.
Old Mar 26, 2014 | 01:04 AM
bbyer's Avatar
Default yes
The compressor is the same from 2005 to 2008 so you will be OK with a compressor off a 2006 LR3.
Old Mar 26, 2014 | 01:22 PM
ljdiscovery's Avatar
you can actually use the compressor out of several different years. I found one out of a 2011 that was the original style. Paid about $130 delivered. Had very low miles and so far has worked great. Check on car-parts.com and search around. Squirt a bit of wd-40 on the hoses fittings before you get ready to take them off, it will save you time, frustration and time at the confessional for words you shouldn't say, ask me how I know.......Good luck.
Old Mar 26, 2014 | 01:40 PM
NIM's Avatar
NIM
Default Compressor
the new style compressor works great, i found them to be a little noisy , but they are great and will need to be program with the latest software
Old Mar 28, 2014 | 06:10 AM
Crosbo's Avatar
"...need to be program with the latest software"???
Old Mar 28, 2014 | 01:08 PM
jafir's Avatar
Yes. The original hitachi compressor and the AMK compress use different software in the ride level module. Even if you stick with the hitachi, there is updated software that is supposed to make them run cooler. I've been happy with my old hitachi with a new drier and updated software.
Old Mar 30, 2014 | 06:07 AM
roverguy7's Avatar
I've found the AMK units to be much quieter then the Hitachi. Only times I've had a noisy one is when the upper half of the plastic shell was not properly installed behind the mounting bracket for the valve block, causing it to vibrate.
Old Apr 1, 2014 | 10:23 AM
NIM's Avatar
NIM
Yes the software need to be updated, at the dealer or some aftermarket shop that is capable to perform the update thanks Nim
loco_america
Jun 14, 2012 12:21 AM
fastrx7man
Jan 28, 2012 12:49 PM
mrbowenz
May 18, 2010 05:12 AM
bhorwhat
Sep 9, 2009 06:41 AM
LandRoverDiscoDos
Apr 7, 2007 04:49 PM
