Replacing the air compressor for the air ride
Old Apr 4, 2007 | 05:06 PM
LandRoverDiscoDos's Avatar
Default Replacing the air compressor for the air ride
has anybody replaced the air compressor for the air ride system in a disco 2? If so, are there any special tools anything special i should know about? Any help would be much appreciated
Old Apr 4, 2007 | 06:23 PM
Default RE: Replacing the air compressor for the air ride
There are no special tools. How do you know it is bad? Have you already purchased another one?
Mike
Old Apr 6, 2007 | 04:01 PM
family friend who is a land rover mechanic said it was bad. It ran to much and it would keep popping the fuses and finally quit. But no i havent ordered one. He said he could order me one for roughly 425.00, (new). Do you know of any other deals. Ive considered coil spring conversion but i still dont know.
Old Apr 6, 2007 | 04:33 PM
Darover's Avatar
There's goods ans bads about the SLS. The bad being that you never know when it will let go AGAIN!!!
With coils, it's the end of these worries PERIOD.
I did mine a few weeks ago, and took the opportunity to go with an aftermarket Old Man Emu suspension while converting to coils. My biggest worries was loosing the plush ride quality of the SLS, mainly because I was gonna use the medium heavy duty coils with heavy duty shocks at the rear to avoid sagging when the rear seats are occupied or when the disco is towing or loaded. To my great amazement, I can say that the ride is just as comfortable than with the SLS. I have to admit that the bigger tires ( from 255/65r16 to 265/70r16 ( 2 inches more))could play a part in that comfort.
I'm sure you'll make the right choice for yourself, but don't let the ride quality worries affect your decision .
Good luck,
Darover.
Old Apr 6, 2007 | 09:23 PM
The one thimng always forget when they talk about Disco's and their rear suspensions, the coils alway collapse before they hit 40,000, what does that say about coils.
I replace my bags after 83,000 miles cause they were starting to leak and trust me, my truck has been on trails you wouldn't want to walk over much less drive.
SLS is a great way to go and by far more versital then coils, handles the one sided loads, ride smoother and you can't beat that extra lift when you are coming off a 3 or 4 foot rock ledge.
Mike
Old Apr 7, 2007 | 01:32 PM
Darover's Avatar
O.K for the stock coils, but then again those are guarantied worry free 40 000 miles, while your air bags which you were lucky lasted you that long are just time bombs with no real reliability. Bags can leak, air lines can leak, and compressors can fail.And on top of it all, it has it's own computer!!![&:]
So go with an aftermarket coil and worries are gone.
Just keep in mind that the dealerships hold the coil conversion in stock, while they have to order any SLS part( around here anyways).That right there says a lot....
But hey... to each is own. I personnally see it as one less thing to worry about
Old Apr 7, 2007 | 04:49 PM
Go to this web site and get a price from them for a good used pump.
http://www.roverlandparts.com/
Mike
ljdiscovery
May 28, 2014 09:46 PM
Burfyworld
Apr 1, 2014 10:23 AM
dlacar88
Dec 3, 2010 05:46 PM
robbster91
Jan 28, 2010 11:06 AM
co556guy
Apr 4, 2009 01:47 PM
