Air Springs Unseated?
Hey all, first time posting here but I've been reading you guys for all my Land Rover fixes since I bought a used 2005 LR3 in June. Unfortunately I couldn't find any answers to my current issue.
Recently my EAC compressor died (connecting arm snapped) so I had to replace it. However, during the period that my compressor was dead my front air springs lost all pressure. New compressor works fine and airs everything up perfectly but when I turn the car off and let it sit the front springs begin to lower (~ .5 inch/hour). I've pulled both engine fuses to make sure it wasn't a self leveling issue, pulled and cleaned my front valve block, and still having the same issue.
I read that the air springs can become unseated from being depressurized for extended periods of time and was hoping someone would know how to reseat them correctly. I also remember reading a while back that the seats on the air springs can get gunked up and make for improper seating. So how would I go about cleaning and seating these things?
Thanks!
Thanks!
I haven't heard of that one. It sounds more like the front valve block. Have you disconnected power to it, to see if it still leaks down? You can spray them, and suspect areas with soapy water and check for bubbles. It also could be you have a bad air strut boot (mine did finally go bad). I know of a guy with air new air struts for sale if you end up needed them.
rchrd0413
04-22-2014 02:18 PM
Bellows Fellow
09-15-2010 02:29 PM
rich
03-07-2010 02:52 PM
