Air strut replacement question
I ordered 2 front air struts to be replaced by my local garage. I know they must be decompressed before removing. The vehicle has been sitting for a couple of weeks and all of the shocks have lowered completely. If I remove the compressor fuse before starting and take it in to the garage, can they be removed without having go through the decompression process? Thanks.
They can unscrew the air line at the strut a little and and bleed some air that way.
2005LR3SE (01-30-2016)
Trying to save the mechanic some time on this job (and me some money), but was not sure how much pressure would still be left so it would be safe. I figured most of the pressure is out now, so this shouldn't pose too much safety risk by skipping the normal decompression process at the valve block.
Thanks
Thanks
arnottdoug
08-05-2015 09:56 AM
