Air Suspension
Old Dec 31, 2018 | 07:07 AM
viewsonic's Avatar
3rd Gear
Default Air Suspension
My suspension takes 68 seconds to raise . Get suspension raising slowly changed rear air block ,.compressor, air tank no leaks . Amber warning light comes on. Suspension does not drop overnight. What else can it be.!!
Old Dec 31, 2018 | 05:59 PM
DakotaTravler's Avatar
Need more details. What are the conditions when this comes up? Has the Rover been operating for a while to be certain reservoir pressure is up and thus compressor off? Generally that alert comes up when the reservoir is empty and the vehicle has to raise solely on the compressor - and typically when going from a position like access to off-road.
Old Jan 2, 2019 | 12:08 PM
viewsonic's Avatar
3rd Gear
It has been happening for a while now changed compressor 2 weeks ago made no difference . Amber light comes on within about 1mile+ I have bought a new airtank to fit but mine looks like it is not that old . my mechanics is going to do a smoke test as ive tried soapy water cant see any leaks.
Old Jan 2, 2019 | 12:16 PM
abran's Avatar
Codes?
what compressor did you install? Cheap eBay AMK knockoff?
Old Jan 2, 2019 | 12:20 PM
viewsonic's Avatar
3rd Gear
No took off a Genuine AMK replaced with same the one I took off is dated 2013. so not that old.
Old Jan 2, 2019 | 02:12 PM
abran's Avatar
Did you change the compressor relay?
and, what are the codes?
Old Jan 3, 2019 | 09:02 PM
EastCoast's Avatar
My 3 is doing the same... amber light comes on after about 5-10 minutes of driving.. doesn't seem to affect anything though no matter how long I drive. Code I get is a communication error but not able to track it down.
Old Jan 4, 2019 | 10:19 AM
abran's Avatar
Are you pulling that code with GAP?
Old Jan 4, 2019 | 04:17 PM
COSPILOT's Avatar
My tank looked brand new at first glance, but the leaks were pinhole sized where the tank is closest to the frame rail. Something to look at.
Old Jan 6, 2019 | 04:25 PM
Coop05's Avatar
Mine has dropped completely snd and wont raise up, light with arrows is on and says suspension fault,looking for help!!
