Air Suspension Leak
Old Sep 23, 2022 | 01:36 PM
Cabezone's Avatar
7th Gear
Default Air Suspension Leak
Hey folks I'm relatively new to the LR3 and could use some guidance. I've got a small leak in the air suspension somewhere. I'm getting these two errors:
This one is permanent:
U0132-87 (28) Lost communication with ride level control module - Bus signal/message failure - missing a message
This one comes and goes:C1A20-64 (2E) Pressure increases too slow when filling reservoir - Algorithm based failure - signal plausibility failure
I did the overnight drop test and got these results:
Front left -1"Front right -3/4"Back left -1"Back right -1/2"
​​​​​​I tried using soapy water to find a leak but couldn't find one.
Any advice on what to look at next?
EDIT: The air compressor seems to be working fine, it gets up to proper PSI when filling. The suspension lifts at normal speed.
Old Sep 23, 2022 | 04:03 PM
douglastic's Avatar
OEM Hitachi?
If so, get a compressor rebuild kit that includes new desiccant, o-rings, spring, and the metal dryer end cap.
Do all that - THEN - wait a few weeks before servicing your front Valve Block.
I have had success just removing, opening, cleaning it out, and putting some silicone spray on the o-rings before re-assembly. (0$)
Some replace the o-rings with a kit ($), others just get a new block ($$$).
Rear valve block may or may not need servicing, but is harder to get to, so save for last.
After my second front block service (I didn't wait after the new desiccant) I have not sagged in - wow - almost 30k miles (over 2 yr)
(I have almost 175k miles)
Old Sep 24, 2022 | 01:04 AM
COSPILOT's Avatar
I'm not going to tell you what to do, but what I did.
The valve blocks are IMO relatively cheap and easy to replace. You mention that rear block, but isn't horribly hard. I chose to replace valves and compressor at the same time years ago on my 2006 at the same time. I think I made the correct choice and everything works. Lr3 can sit for weeks without dropping, which admittedly shocks me as I now have 175K on all of them. I keep thinking I will replace all of them, but they work just fine.
I was getting similar errors way back then, even the dealership wanted to replace the airbags. I gambled and did the compressor and all three valves and won.
Old Sep 28, 2022 | 07:32 PM
Cabezone's Avatar
7th Gear
Originally Posted by douglastic
OEM Hitachi?
Do all that - THEN - was a few weeks before servicing your front Valve Block.
Thanks for the advice. I ordered the service kits and give it a try.
Old Oct 26, 2022 | 03:19 PM
Cabezone's Avatar
7th Gear
I serviced the air compressor a couple of weeks back; changed out the desiccant, O-rings, spring, and cap. It cleared out the "C1A20-64 (2E) Pressure increases too slow when filling reservoir - Algorithm based failure - signal plausibility failure" error.
This weekend I'll service the front valve block and see if that fixed my overnight leakage.
Tnlr4
LR4
Aug 21, 2021 06:50 PM
Rustic
Jun 19, 2020 07:15 AM
jsccinc
Jan 13, 2017 07:27 PM
sDot
Apr 21, 2014 03:07 PM
MoShadeTree
Sep 7, 2013 06:50 PM
