Air Suspension & Off Roading
Old Aug 8, 2016 | 08:56 PM
Columbiar's Avatar
Default Air Suspension & Off Roading
I've heard people say they would never take an air suspension equipped rover out to the middle of nowhere due to the risk of failure and then not being able to get back. The new Rovers North magazine is now advertising their spring convertion kit for exactly this reason. So, for someone like me who is strongly considering upgrading my DII to an LR3, is taking the truck out in the boonies with air suspension really as big of a risk as some make it out to be? Are there precautions you all take to mitigate the risk? For me, the air suspension is one of the cool things about a rover that makes it different from every othe truck on the road.
Old Aug 9, 2016 | 12:54 AM
houm_wa's Avatar
Default Yes...
Mostly if you have an IIDTool you can keep the EAS happy. Not that many issues cause the EAS to deflate. Additionally if you are that remote and the terrain is not too technical you can pull the EAS fuses and be less exposed to EAS faults. I say this about the terrain technicality because going with one of these coil conversions diminishes the off-road capabilities of the LR3.
Old Aug 16, 2016 | 08:13 AM
ericcooke's Avatar
I have read several posts that mention bypassing parts of the EAS if need be to re-inflate your air suspension. I need to find those to learn more myself.
Old Aug 16, 2016 | 08:43 AM
cmb6s's Avatar
If you have an IID tool (or something similar), then the only thing that will leave you stranded is a complete catastrophic failure (e.g. compressor completely fails, air bag or air line ruptures, etc.). IMHO, if you properly maintain your compressor, a catastrophic failure is a pretty rare occurrence assuming you don't bash it on a rock. Failure of an air line is extremely rare... not sure I've ever heard of it happening actually. Failure of a shock might be a little more likely as the vehicle ages, but still not anything I'd worry about out on the trail. Most of the errors that you experience are sensor issues, which can be easily overcome with the IID tool.
Old Aug 16, 2016 | 10:34 AM
jhmover's Avatar
My old D2 blew a rear air bag about 50 miles north of I-80. Fortunately the bag blew off and wasn't damaged. Some siamesed hose clamps fixed it to get back. I put in rear OME's. My 99 Range Rover has springs. Don't need spare air bags, lines, compressor, etc. It's a bunch to worry about and a bunch of spares to carry. I don't need the hassle.
Now if I mainly drove it only on the street I'd possibly have the air suspension on it.
Old Aug 16, 2016 | 01:54 PM
ericcooke's Avatar
Pulling the air suspension on DIIs and Range Rovers is one thing but the LR3 system is pretty awesome. I don't want to lose the ability to raise and lower the suspension if I don't have to. Running a 2.5" Proud Rhino lift and having the ability to go up another 2" can't be beat.
Now if I could run a 4.5-5" lift all the time without tearing up the suspension? I would consider that.
Old Aug 16, 2016 | 05:11 PM
houm_wa's Avatar
Agreed, the LR3's EAS is vastly different than that of its predecessors. It's not just the raising and lowering that is a benefit, but to me most importantly, the cross-link valving. Without the EAS a wheel on the opposite side of a stuffed tire will just dangle in the air by its spring (via gravity) where by with the EAS that suspended wheel would get pushed down to seek ground via cross-linked air.
I didn't think much of this until I saw a picture of this at work (on my vehicle). Now I don't down-play the significance of this feature.
Old Aug 17, 2016 | 03:21 PM
DavC's Avatar
EAS is reliable. IID tool or like is a must. In a pinch yes pull fuses, you can even open up the relay and manually force the air compressor to cycle but this is complicated. Once you understand the system it is fairly simple. Couple spare valve blocks maybe, a few fittings, a few struts in a really remote area. I can see the appeal of springs but I have not yet been let down by EAS. Plus it is nice leveling out the vehicle when it is loaded to the gills and still sits high and tight.
Old Aug 17, 2016 | 06:31 PM
jhmover's Avatar
Blowing a bag or down on the bump stops with a 50 mile walk to the nearest highway will cure you.
Old Aug 17, 2016 | 06:37 PM
I don't trust Rover air suspension, that was my tune before the LR3. That system is amazing and simply put works. Gap tool and I would drive it any where. Hell I'd adapt it for my 110 if I could.
If you want to neuter your LR3 I'll gladly give you a few bucks for the shipping cost for 4 good air struts and a compressor
cruzer555
Jan 11, 2014 07:15 PM
wolfgang528
Defender
Dec 28, 2010 04:25 PM
amukamal
Aug 15, 2006 05:24 PM
05LandRover
May 9, 2005 01:02 AM
