Anyone know how to change a bulb??
Old Mar 12, 2008 | 06:08 PM
shanem37's Avatar
4th Gear
Default Anyone know how to change a bulb??
My Driverside Front signal light is out. I tried to change it, but I couldn't figur it out. Has anyone done this before? Please help, I'd rather not have to bring it in. Thanks.
Old Mar 13, 2008 | 03:09 AM
Dagun's Avatar
6th Gear
Default RE: Anyone know how to change a bulb??
Open your cargo doors, you will see a black strip of plastic extend from your tail light with two screws holding it in place. Unscrew them and then pull out the entire tail light. The other side is not screwed in. The entire light should pull out, be careful if you use a screwdriver that you don't break the light. The entire light pulls straight out. Once out unscrew and replace the bad bulb from the back, test it before you screw everything back in. Overall real simple, just 2 screws holding it in place.
Old Mar 13, 2008 | 06:11 AM
drzjoint's Avatar
i had 2 lights out a few months ago and it took 10 mins at the most and i did both sides the manual has some nice pictures as well
Old Mar 13, 2008 | 11:50 AM
Jantiz's Avatar
Check the Owner's manual towards the back. Step by step for all your bulb locations with great pictures under the heading "cough" "Bulb replacement"
Old Mar 19, 2008 | 10:52 PM
socalrover84's Avatar
you mean the fender light or the headlight ? if its the headlight you will have to remove the headlamp assembly by pulling two slider locks up ontop of the headlight and the lamp will slide out.
collin Barrows
Aug 28, 2011 07:13 AM
Classklown90
Aug 21, 2010 07:24 PM
riggskwong41
Oct 14, 2008 12:24 AM
jcw
Dec 3, 2005 02:21 PM
AzCamel
Jun 14, 2005 08:39 PM
