Is anyone running this
32" tires do fit with some rubbing in the rear. A 33" tire will probably be to wide and tall. It will not fit yet. If you get the spacer kit and combine it with my rods a 33" tire would fit if you can find one narrow enuf in an 18-19" rim. A 12.50 is to wide. both in offroad mode if I remember correctly that pic is over a year old.
LR3 Lift Kit
The rods are essentially tricking the computer to think the airbags need more air to reach "normal" ride height. The computer compensates by pumping them up higher. The actual height is 2" higher while the computer thinks its still in normal height. By switching to either "access" height or "off road" height the computer still adds or releases air like usual but the rods have added 2" regardless of height setting.
In a nutshell...
New ACCESS mode = old NORMAL height
New NORMAL mode = old OFF ROAD height
New OFF ROAD mode = old EXTENDED OFF ROAD height.
I've had these rods for a while and run them everyday. They were very easy to install. Took 2 minutes a side....while I was getting the new (larger) tires installed at the shop.
In a nutshell...
Greg
Suspension lift rods in Extended Mode
OK; Say I fit these rods to trick the computer into raising the 4WD 50 mm.
What happens if I get stuck and the 4WD automatically goes into Extended Mode (p179-180 of the manual)? Does it still raise the suspension further, and if it does; if I invoke the additional lift manually while in Extended Mode, can the suspension cope with this significant increase in lift.
Or does it go POP!, and leave me stranded in the ditch miles from home?
Ques 2: I would like to raise the vehicle when I am off road, and if it only takes a few minutes to do as another user suggested, there’s no reason why I couldn’t put them on for off-road driving, and take them off again when we get home. It’s a great vehicle to drive around town, but my short wife would complain about climbing so high to get in and out all the time. The main issue is if the rods are fitted, will Extended Mode do damage to the suspension?
This raises another question I have: Does anyone know a way of invoking Extended Mode manually, as I think it would be very useful when doing water crossings?
Regards Barry
Regards Barry
answer
No It wont go pop, you will be ok. some guys will get a fault that says the vehicle can't go any higher which will reset if you turn off and then restart vehicle which happens when the you put the vehicle in super ext mode with the rods. You can obtain super ext mode when ext mode is activated, you depress your brake and hold the height switch for about 3-5sec. that is why I do a 10mm lift. 10-13mm is a good leingth some guys run 12mm. I OFFER BOTH 10 OR 12MM. I wont make them any shorter than 12mm. I know a few who run 14mm and are ok.
ans
With the rods I have been making for years I can swap them in less than 15 min. Alot of guys do this. some of my clients even have another set of rims.
ans
Yes if you lower your vehicle onto a jack or log/roch to get yourself highcentered when going from off road mode to normal moed super extended mode will be invoked. If you have any ?s just holler I have ben dooing this for as long as just about anyone in the states. there were a handfull of us who brought this to the us and have been testing it.
answer
ans
ans
