auto climate control, heat
2005. When the car first starts in cold 20 degree weather the blower motor and heat respond well to get the cabin to the set temperature. However, once the car has been warmed up and I go in a store for a half hour or so, the blower motor and temperature do not surge or respond as quickly to maintain the cabin temperature it seems. If I have the cabin temp set to 76 and the car has sat overnight, the blower and the temperature work loud and fast to get the car to 76. If the cabin drops to 60 the car seems to just sort of sip or slowly respond to get the car back to 76.
Is this the factory setting?
Any ideas on what to look at next?
Thanks
Christian
Thanks
Christian
Try cleaning the interior ambient air temperature sensor. Its behind a tiny plastic grill on the dash. They get covered in dust and if really bad cause delays in temperature readings. But more importantly, make sure its air tube is hooked up. Air has to pass the sensor for it to get a reading, so if this tube is not hooked up it will get bad data for the system to figure out. The far end of the tube should be hooked up near the blower motor. Of course the sensor itself could be bad.
temp sensor
I inspected and cleaned the temperature sensor. I tried to remove the sensor from the dash, I was only able to wiggle it out a half inch.
How might I test the sensor to see if it needs to be replaced?
Also, where is the hose attached near the blower, I could not find that end.
Thanks
Christian
Thanks
Christian
englc
06-04-2008 05:43 PM
