AUX Input- How to fabricate one?
Old Jul 12, 2007 | 09:52 PM
arijfeli's Avatar
Default AUX Input- How to fabricate one?
I own a 2006 LR3, US model. It is the 'bare bones'model , as I call it. Here is the trick, the radio (land Rover brand)has an AUX output but the unit came with no wiring for it (the is no 3.5mm plug behind the console). How can I connect a female jackto the radio? I have taken appart the radio but I need to know exactly wich are the pins to connect the plug.
Old Jul 13, 2007 | 12:41 AM
jimbiram's Avatar
Default RE: AUX Input- How to fabricate one?
I am not sure, but my aux input is in the back side of the console between the front seats. I have the HSE, so it has everything. I thought they all had the aux input between the two front seats, facing the rear seats.
Old Jul 17, 2007 | 11:27 AM
Jantiz's Avatar
So did I to be honest!
Old Jul 28, 2007 | 03:08 PM
fanatic516's Avatar
I am a new LR3 owner (5 days) and not to hi-jack this thread, but I plugged my wifes ipod shuffle into the aux jack and I don't hear anything coming from it. I turned the stereo to the aux mode. Is there something else i must do in order to hear a device through the aux jack?
Thanks,
Jason
Old Jul 28, 2007 | 10:23 PM
Max_A6's Avatar
check this thread - https://landroverforums.com/m_26890/tm.htm
Old Aug 14, 2007 | 10:24 PM
arijfeli's Avatar
Long time-out, Sorry. Still no AUX jack to plug the iPod. Any Ideas?
Old Aug 17, 2007 | 11:14 AM
LR3zyfasheezy's Avatar
I was under the impression that all LR3's had working AUX inputs aswell. I guess not.
For "Fanatic516", make sure you turn the volume all the way up on the ipod, or the sound won't as good. This may be accounting for the lack of sound aswell.
Old Aug 17, 2007 | 07:06 PM
arijfeli's Avatar
For some rea$$$on Land Rover decided to skip the Aux Jack even if the radio has this capability
Old Aug 19, 2007 | 11:21 PM
I looked in my LR3 today, and had trouble finding one for a while. Look under the air vents on the back of the center consol. Thats where mine was.
Old Aug 20, 2007 | 07:25 AM
arijfeli's Avatar
Yes, the plug SHOULD be ther, but in the trim line that I have (basic) there is none. In fact, I took the cover off and there weresome unused plugs, but I am unebleto identify wich is the one that I should use to connect the radio. Itook the radioout ad again there are some pins on the connection plug that are unused but I don'thave a diagram to work with. The LR dealer was unable to providea usefull wiring diagram. Did you know that if you unplug the radio, the engine will not start? That is just way too much...
