Battery died and now....immobilizer?
Old Jun 8, 2015 | 03:17 PM
4thefamily's Avatar
Exclamation Battery died and now....immobilizer?
So I bought this rig and found that it needed some work.
So I sent it to a shop for some work and they pulled some codes. I agreed to the work and they let the battery die while working on it.
Now they have recharged the battery and tell me that the immobilizer won't let the LR3 start.
They are telling me it could be wires and tracing and since I have already agreed to 3K worth of work I don't want them chasing ghosts for 125.00 per hour bringing my bill up to god knows how much when I pick it up.
I have read on here that when the battery dies funky things can happen with the electronics.
Could someone please give me some help with this immobilizer issue?
Old Jun 8, 2015 | 06:58 PM
unseenone's Avatar
I believe for security reasons, the only one that can reset the immobilizer is the dealer. Buy a Deka 9A94 battery. Try try an independent shop if you can't swing the labor rates and do not want to do it yourself.
If you do want to do it yourself, then you'll find help here.
Old Jun 8, 2015 | 07:55 PM
4thefamily's Avatar
Default New battery
The battery is only a month old.
I originally brought them the Landy because I wanted to make sure it didn't need an engine. Maybe I was overlooking something.
While it was there, they replaced the EPB actuator, lower tie rod, and the upper radiator hose. While doing that, they drained the battery and now they are telling me that the thing is immobilized. So I am going there in the morning for some face time.
They are an indie shop and they should have the computers to diagnose the problem.
Old Jun 9, 2015 | 08:36 AM
unseenone's Avatar
OK, I just believe the dealer will need to do this. There's a good chance they know someone at the local dealership, so they should be able to resolve it. They should have had a charger on it to do anything with the computers, diagnostics etc.. so it seems like it's their fault and their problem to resolve with your cooperation hopefully. Stuff happens, now it's their response that matters.
Old Jun 9, 2015 | 08:54 AM
4thefamily's Avatar
Default Pic of instrument cluster
Here is a pic of what I saw this morning. They are going to make it right and keep to their word. Good group of guys.
But if anyone has seen this before it would be helpful to chime in,......
Old Jun 9, 2015 | 10:26 AM
jafir's Avatar
That E instead of park makes me think it doesn't know what gear it's in. And it's not going to start unless it thinks it's in Park or Neutral.
Old Jun 9, 2015 | 10:31 AM
4thefamily's Avatar
Ok, thanks for the input. Weird. I have been looking all over online for something.
They are chasing wiring right now. Seems that the harness for the EBP had been botched at one point so the tech had to deal with that too.
Old Apr 24, 2022 | 03:55 AM
Kasim's Avatar
4th Gear
Default Immobiliser issue
Hi
Looking online and came across the photo you have posted online and believed to have immobiliser issue.
my dashboard looks like the photo and am wondering if you did end up finding out what the issue was? If so can you please help?
Kind Regards,
Old Aug 4, 2023 | 11:12 AM
NotOverRover's Avatar
Default '08 LR2 Similar problem
Originally Posted by Kasim
Hi
Kind Regards,
I could not find the other end of this thread, did either of you ever find what the problem was?
Old Feb 18, 2025 | 09:22 PM
Seanyboy24's Avatar
What does the E stand for on the instrument panel?
